The quest for 400/400
Old May 18, 2009 | 12:19 AM
john.schuber's Avatar
So I came to the realization that a turbo kit, built block or even the fp red are just not going to happen if I don't want to break the bank. I'm trying to maximize my fun factor, while at the same time coming up with a reasonable budget and not overextend myself into debt. I figured $5000 dollars will give me 400/400+ making a perfect street car. I think $5000 is reasonable investment, as some turbo kits or a built motor cost more then that alone. Here is a list of the stages I'm planning and will hopefully complete 1 stage about every 3 months. I want to keep the stock turbo as even the red is unnecessary for my goals and I would not be able to fully utilize their true power potential (safely) and I'm not willing to pay the price of the excess lag without the excess power.
POWER
- Stage 0 (current)
- Ams JDM Turboback with test pipe
- AEM Tru Boost Controller/Gauge
- K&N Filter
- ETS LP2
- EPM 02 Dump
Stage 1
- Buschur ported coated exhaust manifold black $195
- Perrin Air Filter $50
- Buschur Intake Piping Black $210
- Walbaro Fuel Pump $110
- Buschur Ported Intake Manifold $150
- Buschur Ported Throttle Body $300
- Aem Uego Wideband $200
- Total- $1215
Stage 2
- Cosworth M3’s $600
- Kiggly spings and retainers $450
- ARP head studs $110
- ARP main studs $76
- Precision Injectors 1000-1200cc $345
- Total-$1581
Stage 3
- Buschur 4 inch black intercooler $800
- Buschur Black UICP $334
- AMS Racing Battery $300
- Total- $1434
Stage 4
- Aquamist HFS-6 $900
- Grand Total $5130
Old May 18, 2009 | 12:45 AM
cornercarver's Avatar
You can totally dumb this list down and still easily accomplish 400+whp on a mustang dyno:
- Stage 0 (current)
- K&N Filter
- ETS LP2
- EPM 02 Dump
Stage 1
- ARP Headstuds $110
- Precision Injectors 1200cc $345
- 91oct+E85 Dual Map tune ~$600
-Total $1415
-315-340whp (A friend of mine recently made 353whp with this setup on E85, minus the 02 dump)
Stage 2
-Total $600
-340whp-400whp (400whp achieved on GST's dyno by Bryan on a stock turbo IX)
Stage 3
- ETS intercooler $500
-Total $500
~400whp
Stage 4
-FP Red or CBRD BBK Full $1700
Total $1700
400whp-430whp
Grand total (to transcend 400whp and shipping not included): $4215
Provided you install the parts yourself, $5000 is a large budget to achieve 400whp now days.
Old May 18, 2009 | 06:35 AM
justa4banger's Avatar
all you need is:
e85 tune
1000cc injectors
forge wastegate
fuel pump
turbo back exhaust
ported mani
02 housing
boost controller
good intercooler
and cams on a 9 will put you over 400whp forsure....
if you live in tempe i would reccommend you wingzperformance (phoung) to get tuned..
http://wingzperformance.com/
Old May 18, 2009 | 06:41 AM
compscibOi's Avatar
Boost controller
TBE (just get a full)
Cams
Fuel: E85 or Pump93+Meth with a larger fuel pump and probably injectors.
Badass tune.
Old May 18, 2009 | 06:51 AM
scheides's Avatar
EvoM Moderator
Do you want 400whp on a dynojet or 400whp on a mustang or 400whp on dyno dynamics? They all read different! 400whp on a dynojet is certainly attainable with the list you have, I like it on an IX, I'd do the Aquamist before doing the cams and maybe even before the FMIC. That's going to be your next best bang/buck item. My VIII made 360whp/348wtq on a dyno dynamics on the IX turbo w/ aquamist, hks 280's, and quite a few of the other mods you have listed above....that will certainly get you in the neighborhood you want to be
Just so you know, on the stock turbo, doing IM/TB isn't going to yield a ton of whp. It WILL however increase transient response, which is pretty much worth its weight in gold
Good luck!
Old May 18, 2009 | 10:16 AM
E-85 is hard to come by in AZ. What would I be at without the aquamist?
Old May 18, 2009 | 10:38 AM
i live in az...and i run e85 everyday and i will never go back to pump, thats all i got to say
Old May 18, 2009 | 10:52 AM
TxEvo8's Avatar
You've got to have e-85 or meth to get to 400/400, or go with a turbo..
Old May 18, 2009 | 11:48 AM
ssteve's Avatar
You can also browse the classifieds for used stuff and save a tone of money. Stuff like ic pipes don't go bad, and if you buy from senior members there's very very little risk in getting ripped off. Use the saved money to have your stock turbo converted to a bbk full.
Old May 18, 2009 | 03:19 PM
what would i be at with all those mods minus e85 or meth
Old May 18, 2009 | 06:00 PM
ssteve's Avatar
Depends on the dyno and gas. In the CA bay area on one of the mustang dyno's on 91 you might fall around 330whp and 350whp.
Old May 18, 2009 | 06:31 PM
griffeyr's Avatar
Unless he plans on doing all the installs himself, he's gonna be out for labor as well
You'd save yourself alot of time and heartache if u do serveral of those installs at the same time, such as turbo, 02 dump and manifold at once
Old May 19, 2009 | 03:28 AM
hybridshooter's Avatar
Looks pretty good, but you forgot one big thing. A clutch to put up with the power.
Old May 19, 2009 | 03:42 AM
1NastyMR's Avatar
M3 Cams are pretty large probably going to need springs / retainers for them
Old May 19, 2009 | 04:49 AM
I have an Exedy Stage II with a Fidanza flywheel
