sputter / backfire (e85 evo)
Old May 25, 2009 | 05:15 PM
rawburt's Avatar
I'm getting a sputtering / backfire at full boost (30 psi). This started happening after about 5 runs down the track. My last run I parked the car and everything was fine. It sat for about an hour. Then on my way home the issue started. Its not throwing any codes. Car is e85 tuned. I already checked the plugs and they look fine. Thoughts?
Old May 25, 2009 | 10:42 PM
selp's Avatar
your spark plugs, you need a new set and a new lower gap.
30 psi? I hope you replaced your stock head studs with ARP ones.
Old May 25, 2009 | 10:43 PM
whiptheevo8's Avatar
+1 on plugs
Old May 25, 2009 | 10:44 PM
ciclops04's Avatar
it happened to me, and i had to do what this selp is saying^^^
Old May 25, 2009 | 11:36 PM
SpooksEvo's Avatar
+2 what selp said. As long as you are sure your timing is good and you don't have anything too crazy, it is probably just plugs and needing a smaller gap. Try em at .20
Old May 26, 2009 | 06:33 AM
rawburt's Avatar
Head studs were definitely replaced with ARP.
I'm currently running the NGK BPR8ES gapped at 0.020” When I pulled them they didn't look bad, I'll pick up a new set today and see how it goes.
Thanks guys.
Old May 26, 2009 | 03:29 PM
rawburt's Avatar
UPDATE: Put some new bpr8es in and its running perfect. thanks for the responses guys, much appreciated.
The real question is, what made these plugs fail in about a month?
Old Aug 2, 2009 | 03:38 PM
Macaroni's Avatar
I'm having the same problem on Q-16 so I don't think it's fuel related. Do you have an ignition amplifier?
Bump to get some answers!
Old Aug 2, 2009 | 05:34 PM
cfdfireman1's Avatar
Don't need an amp. Depending on how they are gapped they tend to open pretty quickly.
Old Aug 2, 2009 | 05:43 PM
Silk's Avatar
Been having the same problem, going through new plugs about every ~1500 miles on my fp red at 32 psi. What about E85 makes me go through plugs so damn fast?
Old Aug 2, 2009 | 06:00 PM
holiday63's Avatar
im running e85 as well(35r at 34psi), i dont go through plugs nearly as fast as i do on pump gas, but im running pretty rich on pump gas.
anyway, i was breaking up really bad through fourth gear pulls on ethanol about a month ago, i had checked the plugs and they didnt seem bad, but thats only because they dont accumulate soot and carbon which is what i was used to looking for.
changed the plugs and i was fine. im using a cop set up so i dont need to gap the plugs down, but plugs do need changed rather frequently.
michaelanjolo
Sep 16, 2015 09:27 AM
doggery
Sep 12, 2015 10:41 PM
boostedrb
Jul 2, 2014 04:43 PM
bigturboevo03
10
Mar 13, 2012 04:55 PM
jlam
Mar 4, 2008 10:27 PM
