Can't remove transmission
Old Jun 7, 2009 | 05:36 AM
Steve93Talon's Avatar
The easiest trick is to use two screwdrivers. One from the bottom access hole and one from the front where the fork goes through. Get them both in position and twist both at the same time and it's guaranteed to pop right off. The only hard part will be shining a light in there so you can see what you're doing.
Old Jun 7, 2009 | 06:40 AM
YellowEvilEvo's Avatar
Originally Posted by dsevo
Forget all that tob bs. I had the same problem, and eventually just took the pressure plate bolts off through the arm hole on the tranny. Its six bolts and maybe took 20 minutes at most. I wish I did that in the first pace, as I wouldn't have f'd up the pressure plate from prying on it so hard. I wouldn't even bother with the tob next time.
I had to do the same thing. Tr tranny came out and then I had to cut the damn TOB off once the tranny was out. This is by far the easies way to do it once the TOB will not pop off!
Old Jun 7, 2009 | 05:57 PM
Piro Fyre's Avatar
I'm still wondering how you guys got to the bolts. I'm having a hard time reaching the first and I don't even know if it's possible to reach the ones on the other side of the hole. What did you guys do to reach those bolts?
Also, I tried the screwdriver and vice grip again and this time, it bent my screwdriver. Great...
Old Jun 7, 2009 | 06:15 PM
You can get to the bolts through the arm hole, with an extension and a swivel. Just rotate the flywheel and the PP will rotate. It doesn't take that long. The hard part is later once you have the tranny off. If the TB took much heat it will be almost welded on there and you will need to cut it off. Good Luck.
Old Jun 7, 2009 | 06:50 PM
Piro Fyre's Avatar
Thanks for the info. At first, I thought the pressure plate was bolted to the block itself. Still learning the curves of a car. Also, any tips on rotating the flywheel and avoid damaging the teeth?
Old Jun 7, 2009 | 06:59 PM
zlthomason's Avatar
you can turn the crank pulley or i used a screw driver doesnt really take much pressure to turn it... i went threw the same **** the other day my tob was pretty much welded in to the wedge collar got it out by taking the clutch fork out oncei had the clutch out i could get the tob off but now have to replace the wedge collar
Old Jun 8, 2009 | 09:59 PM
Piro Fyre's Avatar
Thanks a lot guys. Tranny is dropped but might have to get it serviced by a shop for that TOB.
MitsuJoe
468
Feb 20, 2016 11:17 AM
s.e.a.n.
May 14, 2012 10:41 AM
Mr. EvoVIII
May 16, 2007 07:30 AM
AzNeVo8
Oct 6, 2005 09:37 PM
MitsuJoe
Aug 1, 2004 01:59 PM
