Are you 2.3l guys happy?
Old Jan 8, 2010 | 10:59 AM
  #31
Teal2nnr's Avatar
If i was to got for larger displacment i would go with a 4G64 not a 2.3.....just my opinion. The 4G64 is a better balanced motor then a stroked 4G63..so you get the torque and the rev's..with that being said i'm building a 2.0L.
Old Jan 8, 2010 | 02:43 PM
  #32
MitsoKid's Avatar
I'm currently building a 2.3L 4G63 with Jackson Automotive. for my 05 track car
I road race with NASA a couple of times a year, and do Auto-X. I am running the FP Red on a JAM Stage 1 head w/ HKS 264 cams for the better response. I'm planning on revving to 7,800 consistently with this setup.
I was going for a built 2.0L again, thats what I have now but now that its time for a rebuild I'm going with the 2.3L to really help with corner exit and throttle control. I was having serious problems directly after shifts.. This should fix my problem
All of this, (block prep/machine work/balancing/blueprinting/parts/labor/head work and the shipping) is $3,780. Its really not a bad deal if your looking for more torque
Hope this helped some.. GL
I'll update when she's running again in a few weeks!
Old Jan 14, 2010 | 04:50 PM
  #33
compscibOi's Avatar
bump for more responses.
Old Jan 14, 2010 | 04:56 PM
  #34
tscompusa2's Avatar
whatever you do if you delete balance shafts do NOT get solid mounts unless you want a big vibrator for your gf/wife.
Old Jan 14, 2010 | 08:03 PM
  #35
Gary@MellonRacing's Avatar
on a 2.3 its better to use the ams balancer kit
Old Jan 14, 2010 | 08:05 PM
  #36
tscompusa2's Avatar
i disagree. and their balancer kit would create MORE vibrations.
Old Jan 14, 2010 | 08:06 PM
  #37
JordanS4's Avatar
I love my JAM Stage II 2.3...they use the stock B.S. but machine it and there is no vibration at all.
Old Jan 14, 2010 | 08:09 PM
  #38
tscompusa2's Avatar
there is next to no vibration on any 2.3 with the stock mounts.. put on solid mounts and your 2.3 will vibrate the car like hell.
Old Jan 14, 2010 | 10:24 PM
  #39
compscibOi's Avatar
Anyone seen any results from a 4g64 or a 2.3L stroked 4g63 on a FP Red on E85? I personally think that would be one nasty setup with a fast spool and gobs of torque.
Old Jan 15, 2010 | 12:04 AM
  #40
grim~'s Avatar
so would a blox front mount with stock side mounts be fine on a 2.3
Old Jan 15, 2010 | 12:24 AM
  #41
xRoguex's Avatar
I have the 2.4 on 93 with a red. If e85 was closer id run it. =(
Old Jan 15, 2010 | 12:33 AM
  #42
Davethewave's Avatar
im surprised no one has mentioned that buschur makes a 2.1L kit. im really considering it. good rev range, more torque. whats not to like?
Old Jan 15, 2010 | 01:03 AM
  #43
4g63smokinall4s's Avatar
Originally Posted by threefiveR
I love my 2.3. It revs to 9k and pushes the ams 850r like stock. Its the ams 2.3rr, thats what makes the rev difference. I think as far as daily, the torque is nice and the spool is like late 3k's. Now as far as revs go, its comparable to a built 2l. All in all, a high reving 2.3l is where its at.
would love to get the rr thats prolly the only 2.3 i would get but the price is steep
Originally Posted by Sharkbite2000
If I had to do it again, I would probably do a 2.0 fully built, built head,6262 turbo and call it a day
probalby the same route i am gonna go.. i luv to rev out high and thats the turbo i was lookin at for a fully built 2.0
Is the gearing really that bad? Do you have stock gearing for a IX? If not, how about getting longer gears like the VIII has?
I've contemplated doing this. Built 4g64 for ultra fast spool and massive low torque.
I'm still on the fence about it, keep the comments coming.
i have always been on the fence between a 2.3 and 2.0 but lik i said above i luv revin out high so been leaning to a 2.0 cause the 2.3rr is really the only safe option i see revving out that high... built 2.0 is where its at i think for drag and street applications.. but yes keep the comments comin!
Old Jan 15, 2010 | 12:28 PM
  #44
grim~'s Avatar
so the consensus is...if you goto the drag stip 2-3 times a year go with a 2.3,but if you want to make you car into a drag evo to go with a 2.0?
Old Jan 15, 2010 | 03:31 PM
  #45
tscompusa2's Avatar
The only mount that creates the vibration is the rear transmission / engine roll stop mount. do not change that from stock.
the front trans mount is fine, i have that aftermarket on mine and no vibrations.. I'm not sure about the 2 front side mounts.
