Are you 2.3l guys happy?
Old Mar 12, 2010 | 09:17 AM
  #61
ssteve's Avatar
Originally Posted by think0rz
whats the cost difference between 2.3 and 2.4 LR setups? it seems anyone considering 2.3 would love a 2.4 since it offers everything wanted out of a 2.3 without the negatives (except price i guess?).
+1... What all is needed for a LR2.4?
Old Mar 12, 2010 | 09:33 AM
  #62
DJ Brett B's Avatar
I would do a built 2.4L 4g64... if the motor was going to have a big turbo I would consider destroking it to 2.2L to gain high end
Old Mar 12, 2010 | 09:40 AM
  #63
shuttlegoose's Avatar
Now that the bigger shops and everyone else is figuring out how to perfect the 2.4 block, I think it will soon become the rebuild of choice. I know it will be for me!
Old Mar 12, 2010 | 09:43 AM
  #64
BLKCarbonEVO's Avatar
The only difference between a std 2.4 and a LR2.4 is the longer 6mm rod making it a LR2.4. It has a better r/s ratio than a std 2.4.
You want to do a LR, no matter what you do. It is a much better combo and r.s ratio on the 2.2 and 2.4. The LR2.2 will rev to 9k and would be a perfect match for a 3582, 3586, or 6262
Mikey
Old Mar 12, 2010 | 10:31 AM
  #65
n2oiroc's Avatar
Mikey
or a 4088r
Old Mar 12, 2010 | 11:01 AM
  #66
Originally Posted by n2oiroc
or a 4088r
Agreed. However, I would push the limit on a build for a 4088. I would want all the displacement that I could while still being able to rev as high as possible. I would do this. Not sure if It is 100% possible but Aaron at ER would be a good person to ask that question to.
LR2.3 Would be a total custom build meaning $$$
4G63 MIVEC Head
4G64 Block 87mm
96mm Crank
160mm R&R Alunimun rod (I think that would max rod length possible, it may be a 159mm but not possitive)
10:1 Custom Wiesco HD Piston (a lot of custom work on the piston)
This would be a LR2.3 and should be capable of 8.5-9k You could talk to Aaron more about doing a LR2.3. He is the go to guy. I'm still learning all the custom build specs. I think that would be pretty nice with a TS 4088 though. It will give you a little more displacement than the LR2.2 but the Rev capability should remain relativly close to that of the LR2.2.
Mikey
Old Mar 12, 2010 | 11:51 AM
  #67
n2oiroc's Avatar
4G63 MIVEC Head
4G64 Block 87mm
96mm Crank
Mikey
that sounds expensive! besides im thinking my turbine housing and cams will choke off top end a bit so ill be fine where i am. ill also be daily driving it in decent weather so no aluminum rods.
Old Mar 12, 2010 | 12:16 PM
  #68
JohnBradley's Avatar
Nitrous, sorry I have been full of fail on the quote for you.
A 4088 full tap out should be somewhere like a 3586 or 6262 from what I have seen.
Aaron
Old Mar 12, 2010 | 12:22 PM
  #69
n2oiroc's Avatar
Aaron
yeah, im not expecting to make more power, i am expecting more response and a more durable turbo though. i originally had a 35r that i was going to put on, but the atp 1.06 turbine housing looked like garbage and i found a guy with the 4088 looking to trade down.
im not in a massive rush for the quote, when you get to it, you get to it.
Old Mar 12, 2010 | 12:32 PM
  #70
Aaron
Aaron was the list I posted above about right for a LR2.3? I was not sure about what rod needed to be used in a combo like that... I think it would be way to much $$$ for may people to entertain anyway.
Mikey
Old Mar 12, 2010 | 12:39 PM
  #71
n2oiroc's Avatar
Mikey
if i had limitless funds, i would do things differently, but given the budget im working with i dont think im giving up much. *crosses fingers*
Old Mar 12, 2010 | 01:55 PM
  #72
Its 97 with a 159mm rod. As I recall its 2306 or something, or do it with a "drop in" at 86.5 and get 2280 the first time around. I need to see if the 97mm crank is still available or I will have to get them built.
Aaron
Old Mar 12, 2010 | 02:04 PM
  #73
Aaron, I'm almost positive K1 makes an off the shelf 97mm crank.
Mikey
Old Mar 12, 2010 | 02:10 PM
  #74
Actually the rod length I would do is 156 on that combo. I am pretty sure the crank was discontinued.
EDIT- only discontinued in anything other than the lightweight. Looking at the catalog I just noticed that the 4G94 uses a 153mm rod. Interesting.
Old Mar 12, 2010 | 02:29 PM
  #75
Doesn't a 4G94 has a 95mm crank or something like that?
Mikey
