Twin disc HELP!!
Old Jun 13, 2009 | 12:48 PM
03evokid's Avatar
Twin disc HELP!!
I just got twin disc installed from a newer clutch company. I never drove a twin disc so I have a couple questions hopefully u guys will know. When I start out in 1st gears sometimes it jerks like the tranny if im going slow it almost feels like wheel hop in a honda but its my tranny... and also when I switch into gears and letting the clutch out it sometime its squeeks/? And in D'cell i get alot of chatter i guess they calll it (vibrating and loud noise almost like a exhaust rattle sound)
Old Jun 13, 2009 | 12:54 PM
9sectalon's Avatar
The only time you should hear a rattle is when you are pushing the clutch in at idle. Otherwise it should work normally... maybe just grab quicker and harder. I hope they got the plates and discs' lined up correctly.
Old Jun 13, 2009 | 12:56 PM
03evokid's Avatar
o your scaring me lined up?? when i take of in first at a slow speed it like bucks the tranny and **** i dono its driffrent i been driving stick shift cars my whole life it is just diffrent!
Old Jun 13, 2009 | 12:58 PM
9sectalon's Avatar
Something doesn't sound right. I don't believe it should be acting like that.
Old Jun 13, 2009 | 07:31 PM
Rushin's Avatar
The squealing sound during engagement is normal. Not every time, but usually when I'm slipping the clutch longer
Old Jun 14, 2009 | 12:12 AM
xspsi4's Avatar
What brand? twin disk is a whole new beast.
Old Jun 14, 2009 | 08:13 AM
03evokid's Avatar
yea if i take of in low rpm it squeeks and everyone just looks at me like wtf lol........
Old Jun 14, 2009 | 08:26 AM
04WWRS's Avatar
Sounds like it's a ceramic or semi ceramic clutch? That's where the squealing or chirping when changing gears comes from. Will probably diminish some over time. The chatter on decel when in gear is normal for a twin. May also have some chatter at idle. As far as the jerking, you just need to rev a little higher when taking off.
Old Jun 14, 2009 | 06:14 PM
03evokid's Avatar
thanks!!^^ i think ur right about all this! bc i reved higher and it feels better
Old Jun 14, 2009 | 08:12 PM
Ted B's Avatar
These things are typical of the metallic, unsprung dual disc clutches (e.g. QM, Tilton, etc.), so you'll just have to get used to it.
FWIW to others who may read this, Exedy and SPEC dual disc clutches do not have these issues.
Old Jun 14, 2009 | 08:17 PM
03evokid's Avatar
ya it was non of those companys its a rather new one that id rather not say... but i got a deal on it and maybe they will fix and tweek some things.. im a test dummy kinda for them and the evo clutchs
