Boost Kicks In EARLY but hits MAX late why ?
Old Oct 6, 2003 | 11:13 AM
Jinu0808's Avatar
Hey guys I have a HKS downpipe installed and also a Greddy profec e-01. Eveyrthing is set up now to 19 psi but the problem I am having is my BOOST will kick in at around 2000RPM which is
good but max boost will be 4500 RPM in first gear. WHy is that ?
Old Oct 6, 2003 | 12:13 PM
RADmitsu's Avatar
Is that in every gear, and does it hold to REDLINE...
Old Oct 6, 2003 | 12:14 PM
Jinu0808's Avatar
only first gear is slower than stock but otheres are fine.
yes it is holding 19 psi to red for 3 rd and 4th gear.
Old Oct 6, 2003 | 12:21 PM
raywong's Avatar
4500 rpm is late??
My stock EVO hits max boost @4800 in 1st gear, 4500 in 2nd, 3900 in 3th, 3600 in 4th...
Is this normal?
Old Oct 6, 2003 | 12:26 PM
Jinu0808's Avatar
Mine hits about 17.5 to 18 psi at 4500rpm in first gear
Second gear i think its close to 3500 rpm and 19 PSI to red
Thrid Gear 3500 rpm 19 psi to red
4th th gear 3500 RPM 19 psi to red
Ebc Settings are
Set 56
Gain 5
Start boost 16
Old Oct 6, 2003 | 12:29 PM
raywong's Avatar
why is mine so late comparing to yours?!
Is it because I don't have an EBC?
Old Oct 6, 2003 | 12:31 PM
Jinu0808's Avatar
well when my car was STOCK I hit 19 psi every gear at 3500RPM
but now first gear is not able to do so anymore after the EBC.
Old Oct 6, 2003 | 12:34 PM
raywong's Avatar
something is wrong with my car...
Old Oct 6, 2003 | 03:35 PM
Jinu0808's Avatar
get some kind of BOOST controller and you should have your problem solved? Since the boost controller will come with there own BOOST solenoid .
Old Oct 6, 2003 | 05:05 PM
RADmitsu's Avatar
Ebc Settings are
Set 56
Gain 5
Start boost 16
Thankyou for posting the settings that you are using... But something that just dawned on me, could the adaptive learning curve affect this... Isn't every car a lil different in that aspect especially when we are talking a couple hundreds of a rpms...
Also using the same EBC or in general the same BC would really give this thread the right answer, or point it in the direction...
CahitGP034
Aug 13, 2015 07:00 AM
wizzo 8
Apr 21, 2012 06:53 AM
aronmatic
20
Apr 24, 2011 08:14 AM
D420mac
Feb 17, 2009 09:01 PM
