FP Green HTA Vs FP Red
Old Jun 20, 2009 | 08:34 AM
  #31
Cali2MDevo8's Avatar
Registered User
Kreionic's (charlie) car made those numbers. Kreionic tunex of course. Charlie is tbe man!! It was on cbrds mustang dyno. I xont recall the tq though. It was on gsc S2 cAms on an evo 9.
Originally Posted by sparky
Yeah, cij, almost 450 Mustang, on 93 pump is really cool! Imagine what it would be capable of on 91 with your Meth injection. I am really curious about the torque curve on that particular car that Chad mentions.
Old Jun 20, 2009 | 08:54 AM
  #32
CBRD's Avatar
I think charlie will tell you that his car was a combination of his budget and tuning, and my suggested parts and tuning...
he asked me what i thought he should do, i gave him the list, he checked everything off, and together with lots of time of us both experimenting with the tune it made MEGA power on our dyno...
for reference, our TA car on pump 93 octane with buschur tuning made 430whp ad 400wtq... with a larger turbo, 2.3 liter, etc...
the BBK does its thing where it needs to
cb
Old Jun 20, 2009 | 08:56 AM
  #33
CBRD's Avatar
here is the list:
Evo ix, stock block, BR head, s2's (my favorite), JM fab intake manifold, JM fab exhaust manifold, BR race fmic, turboback, 880s, fuel pump, RRE intake, JM fab UICP, profec Spec B..
27.6 psi... did 439whp on our dyno 445 whp on another mustang dyno...
peak hp at 8000 rpm, peak torque 3890 in 3rd.
cheers
cb
AGAIN- please PM me about this... i dont want to post anymore i an FP related thread...
Old Jun 21, 2009 | 01:19 AM
  #34
Agent Orange's Avatar
Pics and some info on the new HTA Green now up on FP website.
http://store.forcedperformance.net/m..._Code=Turbo-FP
Looks like a 73mm compressor exducer, and what appears to be the same turbine wheel as the Red. (Hard to tell in the one pic showing turbine wheel though)
Old Jun 21, 2009 | 06:41 AM
  #35
sparky's Avatar
Can this new HTA Green be ordered with the standard IX compressor housing. Or, is it only available with FP's anti-surge compressor housing? I know that the FP Red can be ordered either way. So, likewise, can this new HTA Green be configured with either housing? I imagine so....
Old Jun 21, 2009 | 08:08 AM
  #36
sparky's Avatar
Has FP published or is there a common consensus on the exact wheels being used in this new HTA Green? Obviously, the compressor wheel is a new HTA item. But are there any specs on its diameters and blade configuration. Also, is the HTA Green still using the standard Green's turbine wheel? Does anyone know at this point? Any word from Robert yet?
Old Jun 21, 2009 | 08:20 AM
  #37
sparky's Avatar
Originally Posted by Agent Orange
.....Looks like a 73mm compressor exducer....
Thanks for the link! Didn't you mean to say that it looks like a 73mm "inducer"?
Old Jun 21, 2009 | 08:30 AM
  #38
sparky's Avatar
.... appears to be the same turbine wheel as the Red....
Obviously it has a newly designed and different(than the standard Green)compressor wheel. But, if it were to have the Red's larger turbine wheel as well, then why would they still be calling it a Green?
To my way of thinking it must still retain the standard Green's turbine wheel, and the HTA compressor wheel is the only major change. Otherwise it wouldn't be a Green any longer. It would require a different color nomenclature.
Old Jun 21, 2009 | 09:23 AM
  #39
Steve93Talon's Avatar
It's a 73mm exducer. The Red has a 76mm exducer. I believe the old Green has a 69.5mm exducer. For reference, the HTA3582R has a 59mm inducer and 82mm exducer.
Old Jun 21, 2009 | 11:53 AM
  #40
edogg23's Avatar
Wow that dyno of the hta green at cobb tuning is very impressive, 300 ft-lb of torque at what looks to be about 3250 RPM. That turbo looks amazing! 415 torque 452 hp at 24psi geez I wonder what mods that car had.
Old Jun 22, 2009 | 10:39 AM
  #41
atkins's Avatar
yeah its kind of odd that it is so far off of what the graph we saw on here was. the car on here was fully bolted with head work and cams and didnt come close to those numbers on a dyno jet running more boost, 25psi. would still like to see an independant mustang dyno graph. i know cobb does some testing for fp because they post up quite a bit on nasioc (subaru forum) with initial test results from fp's turbos before anyone can even get them.
jeff
Old Jun 22, 2009 | 04:59 PM
  #42
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
I'm running a Red and made 469@28psi on pump
Old Jun 22, 2009 | 05:06 PM
  #43
If you save and lighten up the last picture showing the turbine wheel, it becomes clear that it's the red turbine, not the TD06SL2R as used in the dare I say 'old' green.
I won't post that here though, don't want to get kicked...
Old Jun 22, 2009 | 07:22 PM
  #44
sparky's Avatar
DBALLZ: At what RPM did you lay down the 469? Nice job
Old Jun 23, 2009 | 02:18 PM
  #45
andrewzaragoza's Avatar
take note that that was done on a 2.3 motor. so on a stock 2L it will probably taker around a few hundred of an rpm later. but the performance is pretty good on pump gas and fairly low boost.
