Grinding sound in neutral...
Old Jun 19, 2009 | 12:48 PM
rane's Avatar
I have an appointment to bring my car into the dealership on Tuesday but figured I'd search around here for a bit first...
My problem is pretty straightforward...I notice a grinding sound at the front end of the car, usually around 3k-4k rpm. At first I thought it was a wheel bearing or the clutch, but it does this even when the car is stationary and in neutral. Gently rev to 3k and you hear what sounds like metal scraping against metal.
The car runs fine but I'm hesitant to take it out too much until I have it looked at. She's a 2006 Evo IX MR with about 42k miles, stock clutch, fresh oil, and the only major mods are what's found in the Buschur stage 1 and 2 kits.
Without a camera I can't actually get the sound online...but does anyone have any ideas?
Old Jun 19, 2009 | 01:00 PM
evo8um's Avatar
i dont know without hearing throw a clip up. i mean it could be the throwout bearing. but is it really loud
Old Jun 19, 2009 | 09:06 PM
xi0V3MR's Avatar
try this. keep your car in neutral and hold the clutch in. then rev the car. if no noise, then its your throw out bearing.
Old Jun 19, 2009 | 09:22 PM
evo8um's Avatar
yeah i was just about to tell you that. you dont even need to rev while you are holding the clutch down. it should just shut up if its that
Old Jun 20, 2009 | 10:50 AM
rane's Avatar
Just tried it. It seems to make the noise at 3k with the clutch in AND out. Either way it starts making the sound.
Video
You can hear it at 6 seconds and 12 seconds in.
Old Jun 20, 2009 | 10:32 PM
xi0V3MR's Avatar
wow that is a weird noise. kind of sounds like something is just vibrating onto something while it hits 3k. you could also try to pin point where its coming from by having a very very very very long screwdriver. probably the length of your whole arm. and with the handle you put it to your ear and place the tip of the screwdriver somewhere on the motor. like place it at different spots of the tranny or motor and see where the sound travels through the screwdriver to your ear the most. kind of works like a doctors stethoscope.
Old Jun 20, 2009 | 10:52 PM
Boltz.'s Avatar
FCOTM Winner
Sounds like a heatshield is rattling. That is a common issue. Check driveshaft and the exhaust shields under the car.
Old Jun 21, 2009 | 05:38 AM
rane's Avatar
Will do, thank you.
rane's Avatar
That sounds...interesting.
Hey I'll give it a shot if it could save me money lol
Old Jun 21, 2009 | 05:46 AM
Berts24's Avatar
I removed, I think, two of the heat sheilds alreaday, and now the third and finaly one is rattling, for me it only rattles when I'm off the gas though
Old Jun 21, 2009 | 08:09 AM
rane's Avatar
Thanks for the tips guys...looks like I need to remember the ol' "Keep It Simple Stupid" concept.
Turns out one of the bolts holding down the exhaust manifold heat shield was loose. I took that off, went for a spin, and there's no noise whatsoever.
Old Jun 22, 2009 | 09:59 PM
xi0V3MR's Avatar
good thing it was simple and saved you some money
Old Jun 23, 2009 | 12:16 AM
huevosrancheros's Avatar
"evom.net" just saved you a ton of money !!!!
weeeeeeeeee
May 17, 2016 01:21 PM
pb91
Jun 8, 2011 02:44 PM
rartist
Aug 11, 2010 06:21 AM
DEBAUCHERY
Aug 7, 2008 05:24 PM
5SSuzuki
13
Jul 8, 2003 09:32 AM
