FP RED,,,80mm OR 63mm Stock >>??
Old Jun 25, 2009 | 07:34 PM
  #31
mt057's Avatar
Originally Posted by GrocMax
The factory EVO9 comp housing is actually a TD07 scroll.
I've yet to see anyone send any data verifying true surge on a Red, or seen it here, they were designed to presurge and not hit true surge. Presurge is fairly harmless, true surge is not. If this phenomena you call 'surge' is happening at part throttle, it isn't surge OR presurge, its pressure differential across the throttle body caused by a variety of things and resulting in your BOV flutter or bucking.
Surge ported covers have extra inlet area available to them, if they are utilized correctly they increase flow. Thus the 'flow enhancement port' terminology.
I saw my boost gauge bounce btwn 28-30psi extremely quickly. With you new housing it simply hits and holds target boost at 30psi. Is this what you are referring to as pre-surge? I am just trying to learn and love the turbo. Thanks for your help.
Old Jun 25, 2009 | 07:40 PM
  #32
Gordian79's Avatar
Originally Posted by dipsetinallday
80mm is also laggier!!
What led you to that conclusion?None of these stock frame turbos(red,Green,bbk,arms etc) are laggier then the next.They all spool a few hundred rpm from each other.which you wont even be able to tell.even the new 80mm red i drove one spools exactly same it just hits harder and pulls stronger.
Old Jun 25, 2009 | 09:05 PM
  #33
k20turbo's Avatar
I am going with the 80mm
elementsk8erq
11
Sep 27, 2012 08:39 AM
dank420
26
Dec 4, 2010 06:06 PM
ilikeppie
26
Feb 14, 2010 08:35 AM
EvowagonIX
36
Nov 18, 2009 12:59 PM
Freddy302
21
Oct 10, 2009 08:11 AM
