Whining noise when AC is on?!?!
Old Jun 29, 2009 | 07:45 PM
NsinEvo8's Avatar
So, i noticed this today... whine noise when ac on then goes off when Ac deactivated.. Anyone experience this, and what is causing it?
Old Jun 30, 2009 | 12:01 AM
Boosted Demon's Avatar
Maybe a loose ground. Do you have an aftermarket stereo? I still have some issues from the previous owners install.
Old Jun 30, 2009 | 12:13 AM
Clutchdc5's Avatar
Could be belt
Old Jun 30, 2009 | 09:12 AM
Carlyle's Avatar
could be pulley as well
Old Jun 30, 2009 | 09:44 AM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
How many miles on the car? If it's up in the 50k's then it's most likely the pulleys and belt just needs to be changed.
Old Jun 30, 2009 | 07:43 PM
NsinEvo8's Avatar
its about 47XXX.. why would it be a pulley? if anything i think belt, but what do i know.. hmm, belts look ok, ill try the conditioner..
Old Jul 1, 2009 | 11:23 AM
barneyb's Avatar
The belt has a recommended service life of 30K. I tried to go 60k but it was looking pretty sorry at 58K and I replaced it. So, try a new belt.
Old Jul 1, 2009 | 10:42 PM
xi0V3MR's Avatar
i see this a lot, try to turn the AC on, and when it squeaks spray some belt dressing on it and it should go away
Old Jul 2, 2009 | 11:09 PM
NsinEvo8's Avatar
^belt dressing? is that the same as conditioner? cuz ill be trying that soon..
Old Jul 2, 2009 | 11:20 PM
HaVoK23's Avatar
what this guy said
Old Jul 2, 2009 | 11:22 PM
wildacex187's Avatar
pulley has a bearing in it no? then it wears with time and needs to be replaced. spraying it will only mask the problem
Old Jul 2, 2009 | 11:23 PM
xi0V3MR's Avatar
i dont know if its the same as conditioner but its just some stuff you spray on your belts to lube them up. get them a little sticky
jjayp
Nov 7, 2016 11:08 PM
Blumenthal300s
May 10, 2014 09:48 PM
pd9000
Jul 21, 2013 11:58 PM
jrsimon27
Lancer Troubleshooting
Jun 25, 2010 07:43 PM
Lethalest1
19
Aug 24, 2009 09:56 PM
