Help with MIVEC camgear
Old Jun 30, 2009 | 01:50 PM
gone2pimp's Avatar
I installed a set of cams last weekend and I disassembled the mivec camgear thinking i can see the dowel pin from the outside of the gear. But i believe i reassembled it wrong cause now the car is giving me code p0011 which is variable valve timing system problem. does anyone know how the gear is suppose to go together ? Or do i need a new gear ?
Old Jun 30, 2009 | 02:48 PM
allinevo's Avatar
Wish I could help but I have never taken one apart(mitsu mivec that is) I have taken other manufacture vvti apart and have had good luck when reassembled as they are quite simple inside. I wish I could help you out but like I said,never had the pleasure of taking one of these apart. Check in the F/S section of the forum as you see the mivec cam gear(intake side) for sale every once and a while. It would be a much cheaper option then buying one from Mitsu. Make sure that you didn't unplug the mivec solenoid and forget to plug it back in before shopping around for another cam gear.
Old Jun 30, 2009 | 07:45 PM
gone2pimp's Avatar
Which plug is for the mivec ? Im pretty sure someone on here had done this before. the car drives just fine no ruff idle or anything. Im thinking about ripping it apart this weekend and see if i can figure this out. would the intake cam being off a tooth cause the code ??
Old Jul 1, 2009 | 05:53 AM
gone2pimp's Avatar
Bump for some help
Old Jul 1, 2009 | 08:35 PM
gone2pimp's Avatar
Maybe someone could upload a pic of the cam gear assembled from a shop manual
Old Jul 2, 2009 | 10:23 AM
gone2pimp's Avatar
Well not getting any help. Can someone tell me where I can buy a factory serice manuel.
Old Jul 2, 2009 | 03:48 PM
evoboi005's Avatar
easier to get a new gear ...
Nelissen
411
Aug 13, 2024 02:06 PM
kemoly
11
Jul 23, 2010 03:42 PM
conner.duncan
Lancer How Tos / Installations
Jul 4, 2008 03:04 PM
Jeller
Feb 10, 2008 10:46 AM
stance
12
Nov 12, 2006 06:35 PM
