Weird 3rd gear shifting problem
Old Jul 31, 2009 | 09:35 PM
AzNvPo4sHo's Avatar
For the past 3 days, I been having a problem with shifting from 2nd gear around 4000 RPM to 3rd gear quickly. It happens around not much, but around 15-25% of the times. Lets say I'm on 2nd gear, I would sometimes shift around 4000 RPM quickly into 3rd gear and it would not go in. It would feel I have not depressed the clutch pedal at all and there is something hard blocking it. However if I'm at a somewhat high RPM on 2nd gear and clutch in for a couple of seconds then shift to 3rd gear, it would go in smoothly. Does anyone know what is going on? The car I'm having problem on is a 2003 Evo VIII GSR with 36k~ miles. Everything is stock on the car too.
Thanks!
Old Aug 1, 2009 | 12:28 AM
NsinEvo8's Avatar
Dam, am having similar prblem. But, shifting quickly at high rpms.. kinda grinds doesnt engage in gear... I havent had time to adjust clutch, you can try that... Or maybe new fluid>?
Old Aug 1, 2009 | 01:56 AM
AzNvPo4sHo's Avatar
I changed all of my transmission/diff/etc. oil not too long ago too. I think it was at around 30k~ miles and right now my car is at 36k~ miles.
Old Aug 1, 2009 | 02:19 AM
MitsuEvo05's Avatar
had the same problem...i took it in to mitsu under warranty...they claimed it was the synchos...checked that!
Old Aug 1, 2009 | 02:45 AM
AzNvPo4sHo's Avatar
Wouldn't I be grinding in 3rd gear if it was synchro problems? It seems like the clutch isn't disengaged when I shift into 3rd
Old Aug 2, 2009 | 06:03 PM
NsinEvo8's Avatar
Did problem happen after fluid changes? +1 for sycro unfortunately, if is not the above
Old Aug 2, 2009 | 08:36 PM
AzNvPo4sHo's Avatar
It was fine after my fluid change, I just noticed it couple of days ago. I can still drive the car perfectly fine, its just that I don't try to rev too high on 2nd gear to 3rd gear. Should I just keep driving it like that and wait to get it fix?
Old Aug 2, 2009 | 08:43 PM
detroit pistins's Avatar
stock clutch? ........i know u said the car is stock
Old Aug 2, 2009 | 08:45 PM
AzNvPo4sHo's Avatar
Yep, I'm still on my stock clutch.
D-Man
Mitsubishi TC-SST Discussion
May 26, 2020 12:02 PM
aycynokia
May 10, 2011 05:33 AM
H8ted1488
Driving Techniques
25
Jan 16, 2010 12:55 PM
monkey_187
38
Feb 27, 2009 03:54 PM
BaLListic_EVO
Driving Techniques
15
Jun 24, 2004 11:55 AM
