View Poll Results: ARP Head Stud Install
One by One
61
49.19%
Remove Head
63
50.81%
Voters: 124. You may not vote on this poll
POLL: ARP Head Stud Install
Let's look at it this way...
Why are you installing stronger head studs? The most likely reason is that you have reason to believe that you will be running a higher boost than the stock ones can handle. Are the headstuds the only weak spot in the head?
My suggestion has always been to replace the headgasket and check all of your other seals, gaskets, etc. to future proof your install. Maintenance should always been in the forefront of your mind before modifications.
This has bee discussed numerous times. Here is a link with all the info and opinions you need.
https://www.evolutionm.net/forums/ev...ight=headstuds
If Done correctly the 1 x 1 method could end up fine. But that being said my personal preference would be to remove the head and replace the head gasket at the same time. I've never been a fan of the one by one method, but it has worked for some......
Yes it was for whether or not people should install them. I wanted to add it to your poll though cause it has some info on whether or not people were experiencing issue after the install. Read into it and you will see. Lets keep this going though and see who else has or has not had issues. Just wanted to share some info!
If you aren't competent to install head studs 1x1 and not mess up your car definately do not attempt to swap the head. That is a much harder job and chances of screwing it up are much higher. Pay someone who can do it to do it right the first time.
im frankly getting tired of people acting so smug, "do a search next time" consider this, as these cars get older, owners are going to gain more experience, new techniques. sure we might be asking the same questions, but the responses are so much more detailed now than they have been in the past.
so the A1 L19 headstuds from ttp, are they the same as the ARP L19?
edit: ttp is right oem is not the thickest headgasket. but oem is pretty good. just stay away from cometic aparently.
dont buy aftermarket headgaskets, OEM ones are the thickest.
so you had the time to point out that i was wrong, but you didnt have the decency to answer my question... which is about a product you carry... awesome
just so we are clear, the blurred out brand is COMETIC!
ive been a member on here for a while now and i have to say, the search feature on this site sucks. and whats worse, most of the old write-ups are so old they are missing pictures, some are even dead ends.
Methodical4u
Evo X How Tos / Installations
28
Jul 5, 2012 04:19 AM
murderedevo256
Mar 6, 2010 08:51 AM
