stock balance shaft
Old Aug 4, 2009 | 03:19 PM
EvoAlex48's Avatar
stock balance shaft
someone please clear this up for me
my balance shaft has lots of play but the dealership says there is no bearing that u can buy and install, its built into the balance shaft....but if its built in then how does it have play???!! i dont have enough money to pay to have my engine pulled out to remove the shaft...i have the eliminator in my old engine, so i could just use that but still cant afford the work..it makes a wierd noise and i dnot want to drive it like that i feel like its gonna break or something on me....
are the dealership retards? or is there some other way it can wobble like that???
Old Aug 4, 2009 | 04:29 PM
nitroboy158's Avatar
Yeah the balance shafts have bearings pressed into the block. If your going to run the elimination kit you still have to remove the bearing and rotate them 90deg to block off the oil feed to balance shaft. It will be a LOT cheaper to fix it than have a shaft stick out the block at 7000rpm
Old Aug 4, 2009 | 04:43 PM
EvoAlex48's Avatar
so how could the balance shaft have play??? and im not driving it lol
Old Aug 4, 2009 | 07:58 PM
barneyb's Avatar
You are saying it does but then asking how could it?
Well, the balance shafts turn at twice crank speed. So, if you wrap to 7K they are doing 14. A lack of lubrication any time this is happening and the bearings will be quickly wiped. I remember people writing to DSMtalk saying they found a balance shaft bearing in the oil pan when they dropped it. It can happen.
Old Aug 4, 2009 | 07:59 PM
TTP Engineering's Avatar
Correct there are bearings. We have NEW in box clevite bearings ready to ship for the balance shafts.
Old Aug 4, 2009 | 08:31 PM
94AWDcoupe's Avatar
what the dealer meant was there is no bearing that "you" can buy and install.
the bearing is pressed into the case and not easy to change. there is a special tool to install them. there is not much info on this because most would choose to eliminate the shafts at first sign of failure. I hate to be the one to tell you but you basically need an engine rebuild at this point. the failing balance shaft bearing will send metal all through out your engine. any repair short of complete tear down will give short lived results.
DEA
Jun 16, 2015 04:10 PM
dsmerjosh
10
Apr 11, 2015 03:27 AM
2k4EvoVIII
26
Jun 30, 2008 10:27 AM
Celica2EVO
Jan 30, 2008 08:16 AM
thebluesky
11
Aug 27, 2006 09:05 PM
