greddy rs bov owners please help
ok so i have a greddy rs bov on the car and at part throttle its flutters like crazy i adjusted both ways and still does
at wide open throttle it runs great
so i just took it apart and it looks like the diaphram is in good condition no tears but there is two springs inside one inside of the other is this normal? or should there only be one
anyways i just want this thing to stop fluttering at partial throttle so any help would be appreciated
thanks
AG
thanks
AG
^^^^yea just found that im going to try that out but i have a red on the car now when i had the stock turbo it worked fine
do you have this on your car with the 35r?
Keep an eye on the diaphragm too. I did the 1 spring mod to mine which helped, but later on it started fluttering again and I opened it up to find several small cuts on the diaphragm.
hey whats going on hows that red doing???
and i had the type rs on mine for a while but couldnt stand the bicking and fluttering at partial throttle so i just put the stocker back on and its so much better not gonna lie and im on 30psi the stocks holding up haha
love the red ....
the one spring thing did help not perfect but alot better
not sure what ill do now since no one seems to have a straight answer on the best bov
might try the aps twin vent
Sell it and get the APS. I've had the Greddy, Forge and now APS.
The APS uses a heavy brass piston instead of a low-mass push rod and diaphragm like the Greddy and Forge. The brass piston is a mass damper for the system and doesn't flutter like the low-mass diaphragms.
You just need to make sure the APS gets taken apart and cleaned every now and then.
The solution is simple. Sell it and buy a stock metal MR or IX bov. Install it, crush it slightly if you want to run more than 30psi. Driveability will be greatly improved and you will hold boost just fine. I ran the forge (tried every possible spring combo) and it sucked. I switched to the RS, same thing but not as bad, but still made me mad as hell @ part throttle. Eventually got sick of it and got an I BOV, and I havent looked back.
i run a red and will do meth soon so the boost will be up there
diiirk@AwdMotorsports
Apr 10, 2008 12:58 PM
