Best pump gas turbo kit
Old Aug 11, 2009 | 09:50 PM
1000AWHP's Avatar
t3 style turbos? Wont that be a little small for those kind of numbers? Especially on pump gas, no...?
Old Aug 12, 2009 | 04:57 AM
riceball777's Avatar
i love my twin scroll hta 35r on pump gas
Old Aug 12, 2009 | 11:16 AM
CoMoEvo's Avatar
if you want a good street/ strip car tune e85 on stock turbo and do cams and full bolt ons.. you want to edge a little more and have a FUN car to drive? tune 93 on a bbk.
you want to be a dyno queen, build your block, run a rotated fetus-eater.
Old Aug 12, 2009 | 02:03 PM
Veronica@TTP's Avatar
https://www.evolutionm.net/forums/ev...tock-fmic.html
Old Aug 12, 2009 | 02:09 PM
SPEED's Avatar
^LOL
ahh yeaaa
Old Aug 12, 2009 | 02:15 PM
aka.ralliart15's Avatar
Yea you definitely need a 35r or bigger to get over 500whp on pump, none of the stock frame turbos will get you there unless you have a FPRed, every single bolt-on, AEM, ported head, IM, etc....you need a bigger turbo for your needs.
Old Aug 12, 2009 | 02:28 PM
Originally Posted by SPEED
^LOL
ahh yeaaa
Yup and the same car does over 605whp on E85 on the same stock block.
Old Aug 12, 2009 | 02:54 PM
CARLITOEVO's Avatar
Old Aug 12, 2009 | 03:18 PM
5LEEPERISAH23I's Avatar
there are many routes... not real answer... denpends on way to many things
Old Aug 12, 2009 | 03:56 PM
EVO8URV8's Avatar
Here u go
Old Aug 12, 2009 | 03:59 PM
High_PSI's Avatar
Originally Posted by Mike@AwdMotorsports
Stock frame turbos are limited on pump gas.. Even FP red the largest of them all doesnt make what 35r based turbos make on pump..
Very True, but look at the area under the Curve, way fatter mid-range on that red turbo.
Old Aug 12, 2009 | 04:09 PM
Sharkbite2000's Avatar
right part's and the right tuner I love the 6262 and 6765.
I'm running 6765/2.3 600awhp pump 93.
Old Aug 12, 2009 | 04:18 PM
1000AWHP's Avatar
LMAO fetus-eater!!!!!
Old Aug 12, 2009 | 04:24 PM
AWD Motorsports's Avatar
All of which i am aware.. The OP didnt ask what turbo would give me the best powerband on stock block..he asked what will make the most HP.. you wont see 550+ on red on pump.. I NEVER recommend t3 based turbos on stock block unless i know they plan to upgrade motor eventually.. FP Red is by far the quickest turbo you can reliably run on stock motor..
Mike
Old Aug 12, 2009 | 04:25 PM
You got a built motor, Ballah..
Mike
