Best pump gas turbo kit
Old Aug 11, 2009 | 05:25 PM
1000AWHP's Avatar
I was thinking about upgrading my turbo...I wanted to know what turbo setup makes the most hp/tq on pump gas. Stock bottom end, stock ecu. Thanks.
Old Aug 11, 2009 | 05:28 PM
TURBevO8's Avatar
CBRD BBK.
There are some other options too. Search around for stock frame pump gas turbos. Lots of info out there.
Old Aug 11, 2009 | 05:29 PM
AWD Motorsports's Avatar
Turbos dont make just HP on pump gas.. Good combinations , Tuning and setups do.. Maybe search around on the Buschur 9 sec pump gas setup.. here are some examples if you search.. While these are built cars you get an idea of whats involved to make the HP..
https://www.evolutionm.net/forums/ev...ay-office.html
https://www.evolutionm.net/forums/se...er-engine.html
https://www.evolutionm.net/forums/ev...e-gas-evo.html
Old Aug 11, 2009 | 05:30 PM
Originally Posted by TURBevO8
CBRD BBK.
Stock frame turbos are limited on pump gas.. Even FP red the largest of them all doesnt make what 35r based turbos make on pump..
Old Aug 11, 2009 | 05:34 PM
1000AWHP's Avatar
Gees...Bushur sure has mastered pump gas setups. Is the 35r the smallest that can make 500whp on pump? The other two they used seem a little bigger...i think?
Old Aug 11, 2009 | 05:35 PM
localtoys73's Avatar
red will make 500 on e85 pump
35r's, Precision 6262, FP Hta's all good pump gas turbos.. Stock frame turbos will not make with a t3 turbo will make on pump..
Old Aug 11, 2009 | 05:36 PM
I was assuming he meant 93.. We usually dont refer to e85 as pump.. Red has made 630whp on E85 also..
Old Aug 11, 2009 | 05:37 PM
i just looked that he was down in miami which i think has quite a few e85 stations but yea i aggree
the 6262 is a great turbo i think
Old Aug 11, 2009 | 05:39 PM
boostedwrx's Avatar
Depends on what you want. Sure you can make 500whp on a 35r but all that power is from 5k up. Slap a BBK or similar on, make 400whp+ and have a lot more enjoyable of a car on the street IMO. If your building a highway or 1/4 mile car then get the big turbo.
Old Aug 11, 2009 | 05:41 PM
1000AWHP's Avatar
Yeah, i wanted 93oct. e85 is a mission to get. plus i might move back to where there is none. Hmmm...Is there a cheapest of those turbos named? What about cams for these turbos...?
Old Aug 11, 2009 | 05:42 PM
1000AWHP's Avatar
Yeah...and which would have the characteristics of a smaller turbo? Quickest spool...?
Old Aug 11, 2009 | 08:19 PM
EvoLutionized8's Avatar
I have read 5 different threads on this exact same question just tonight. I think you are looking for an FP green HTA 73, Red, BBK, Tomei ARMS.... they are all stock looking turbos, but have been doing real well on pump. I just named a few, but there are so many kits out there now, that its all going to depend on what you're looking for in driveability.
Old Aug 11, 2009 | 09:20 PM
1000AWHP's Avatar
i think my main concern is power. Im not going to be running high boost all the time, but I really would like to make near 500whp on pump for the faster cars. I either drag or roll race...
Old Aug 11, 2009 | 09:27 PM
atkins's Avatar
Originally Posted by 1000AWHP
i think my main concern is power. Im not going to be running high boost all the time, but I really would like to make near 500whp on pump for the faster cars. I either drag or drag race...
fixed
check out a couple of t3 style turbos they should meet your needs, also with some of the stock ecu advancements being made you can now map switch so you could always have a low and high boost map for that special occasion
