Problems with the walbro 255
Old Aug 12, 2009 | 01:07 PM
Evo9RS's Avatar
I successfully installed the walbro 255 correctly. Next day I start my car and everything seems fine. I drive about a half mile and my car starts to die! I didn't have gas in my car, the light was on and I was on my way to fill her up.
You think I would have to put gas in it to get the fuel pump running on some fuel??
Old Aug 12, 2009 | 01:18 PM
05blue8's Avatar
Huh? How is that a problem with the 255 if you ran out of gas? Just get a jug, put a gallon in and go to a gas station...I'm confused...
Old Aug 12, 2009 | 01:19 PM
travman's Avatar
well normally for a fuel pump / car to run you need gas in it.......makes sense that the car stopped running when you were out of fuel..
but yeah blame the walbro for you running the car empty
Old Aug 12, 2009 | 01:33 PM
knightrider4g63's Avatar
Old Aug 12, 2009 | 01:36 PM
Evo9RS's Avatar
well i put gas in it and it still doesn't want to start.
Old Aug 12, 2009 | 01:37 PM
Evo9RS's Avatar
the car cranks and everything but it doesn't seem like it doesn't want to start at all..
Old Aug 12, 2009 | 01:38 PM
Rxracer's Avatar
Put gas in it and everything will be fine...
Old Aug 12, 2009 | 01:40 PM
Kracka's Avatar
Can you hear the fuel pump turning on? If not double check all the connections.
Rxracer's Avatar
i know my fuel gromment failed at the top of my pump after i got my car, that would casue issues like that, mine would barely run.. other than that i cant help ya..
Old Aug 12, 2009 | 01:48 PM
Evo9RS's Avatar
Yes, I can hear the fuel pump but i'll check the grommet
Evo9RS's Avatar
[IMG]<a href="http://s56.photobucket.com/albums/g161/Blu3wir3/?action=view&current=step_231.jpg" target="_blank"><img src="http://i56.photobucket.com/albums/g161/Blu3wir3/step_231.jpg" border="0" alt="fuel pump"></a>[/IMG]
Old Aug 12, 2009 | 01:53 PM
Evo9RS's Avatar
If the grommet is the solution, where would i get one to replace it?
Old Aug 12, 2009 | 01:59 PM
Rxracer's Avatar
The only place is from the dealer.. the part number is
MR431121 they are 2.50~ or so. i ordered a spare when mine failed..
Old Aug 12, 2009 | 02:01 PM
Rxracer's Avatar
BTW that is the one that was for a 8, i donno about the 9, it should be the same..
anyone with some experience with a 9 wanna step in and confirm this.....
Old Aug 12, 2009 | 02:09 PM
nonschlont's Avatar
I had a similar issue, but I actually had a 1/2 tank of gas, but the guage was reading empty, and the car wouldnt start...
(my solution) was to pull the entire sender unit/FP out, pull out the FP from the sender unit, and check to see if the wire is connected, as mine was not... Connected it, and it started up and off you go... hopefully...
Evoixjohn
Dec 26, 2014 08:28 PM
EvoAznBoi
Nov 16, 2011 03:35 PM
06MREvo
50
Mar 5, 2011 07:04 PM
Stroke It
Aug 4, 2010 11:14 AM
TangoASI
Aug 24, 2008 05:54 AM
