Buschur MBC Install
Old Aug 14, 2009 | 04:39 AM
njboy's Avatar
Buschur MBC Install
I looked and can't find a "do it once" install of the Buschur MBC. What end gets hooked to which hose. A picture would be the best. Thanks for any information.
Old Aug 14, 2009 | 05:00 AM
Danner's Avatar
Run one end to wastegate nipple and the other end tap into the line going to bypass valve. Then You plug off the nipple on compressor of turbo and the nipple on boost solenoid located under intake filter.
Unless you have a tune, a mbc is not necessary.
Old Aug 14, 2009 | 05:14 AM
sparky's Avatar
1st decide whether you want to use the compressor discharge tube's nipple or the DV/IM line as your boost reference source. Does the Buschur MBC come with hoses preattached? If not buy a couple yards of 4mm vacuum hose at you local auto supply house.
Old Aug 14, 2009 | 05:18 AM
sparky's Avatar
Originally Posted by Danner
.... plug off the nipple on compressor of turbo and the nipple on boost solenoid located under intake filter.
He'll also need to plug off the nipple on the MAF pipe(hose?). The nipples on the BCS can be left unplugged, however the BCS's electrical connector should be left plugged-in.
Old Aug 14, 2009 | 05:20 AM
Danner's Avatar
buschur mbc comes with controller and two brass nipples that go in ends. Nothing else. no hose or instructions.
Old Aug 14, 2009 | 05:37 AM
njboy's Avatar
I received from them the MBC, a plastic T, and some hose but no instructions so I don't know which end of the MBC gets connected to what. And instead of flipping a coin I'd ask here....
Old Aug 14, 2009 | 05:42 AM
njboy's Avatar
I'm getting a tune as soon as I get the gauge and MBC installed.
Old Aug 14, 2009 | 06:15 AM
travman's Avatar
I have an idea.........pick up the phone and call the company who made the part and ask them?
Old Aug 14, 2009 | 06:23 AM
TheDream's Avatar
The instructions are on the forum:
www.buschurforums.com
Old Aug 14, 2009 | 06:26 AM
Jrod@Buschur's Avatar
Post #3
http://buschurforums.com/forum/showthread.php?t=22718
Old Aug 14, 2009 | 07:44 AM
njboy's Avatar
Great idea. I've come to rely on this website too much :-)
tscompusa
Sep 27, 2018 03:54 AM
2rbolag
Nov 18, 2016 03:24 PM
ctfpevoVIII
Jul 25, 2015 08:16 AM
Tommy_Lee
Aug 4, 2010 01:34 PM
blue8sc
Apr 20, 2005 03:49 PM
