boost cutting
Old Aug 17, 2009 | 01:43 PM
def1's Avatar
boost cutting
For some reason when my car hits peak boost the boost will then drop to 16 psi and slowly climb back up. This causes the car to go lean and also feels extremely slow. Im thinking that the wastegate is opening prematurely or something because I cant find any boost leaks and my fuel isnt the problem. I have another wastegate so I can just exchange them ad see if this fixes the problem. DO you gys have any other suggestions to check for?
Old Aug 17, 2009 | 02:28 PM
RoadSpike's Avatar
Sure your not hitting fuel cut?
Is this car tuned?
Old Aug 17, 2009 | 02:33 PM
Evo8luva's Avatar
Is this car tuned?
x2
also give us a mod list, including what you are using for boost control.
Old Aug 17, 2009 | 02:56 PM
jyndrus90's Avatar
Any boost leaks?
Old Aug 17, 2009 | 07:00 PM
def1's Avatar
No boost leaks.
Currently getting tuned by mellon and i was hitting boost fine before on the tune.
Mod list:
FP Green
Hks cams
LICP
Ported Ex. Mani
Cone Filter
850 Injectors FIC
Walbro Fuel Pump
02 housing
3 inch exhaust
I think thats all my mods
Old Aug 18, 2009 | 12:23 PM
Mellon Racing's Avatar
did you check the fuel pressure regulator hose yet?
Old Aug 18, 2009 | 10:10 PM
def1's Avatar
yes i did. Its not that. Its my boost controller. I unhooked it and my boost doesnt cut anymore and of course goes way past 25 pounds so i have to let off but before it wouldnt even hit 20 psi so I know this is what it is.
I am just not sure if the vacuum line is torn or if the boost controller went bad. Does anyone know where to get a replacement vacuum line and how to check if the boost controller is working properly
Old Aug 18, 2009 | 10:19 PM
tscompusa2's Avatar
what kind of boost controller is it? ball and spring? please don't say bleeder valve.
Old Aug 19, 2009 | 11:56 AM
def1's Avatar
bleeder valve? I believe its a ball and spring. Its a hallman pro
Old Aug 19, 2009 | 11:58 AM
tscompusa2's Avatar
old school boost controllers are bleeder valves, its like a controlled boost leak.
hallman pro is good. Ive had mine hang up before tho inside. to check just open it up and make sure the ball is not wedged inside the spring. be sure to do this inside (your house) so you dont lose the ball or spring, the ***** very very small.
Old Aug 19, 2009 | 05:15 PM
def1's Avatar
ok thanks Ill check that. If it happens to be the vacuum line is torn. Do you know where they have replacements?
Old Aug 19, 2009 | 05:36 PM
RoadSpike's Avatar
If its just vacuum line your local auto parts store will have line for you.
def1
Feb 2, 2017 10:34 AM
risaac
Sep 5, 2011 10:02 PM
urnamehere
Oct 13, 2010 12:01 PM
neweraevo8
11
Oct 14, 2008 12:09 PM
kmcconn9
Aug 8, 2007 09:10 AM
