No reverse
Old Sep 7, 2009 | 08:49 AM
pensport's Avatar
No reverse
I was wondering if can someone help. All my gears work but when I put it in reverse it acts like neutral. It will slot into reverse but when i release the clutch nothing happens. Im gonna re bleed my clutch and check the linkage under the center console today. Any other insights on the problem? Also I have a 05 Evo 8 and was wandering if the warranty for drivetrain was 100k? Thanks in advance! =(
Old Sep 7, 2009 | 09:10 AM
pensport's Avatar
bump for thoughts
Old Sep 7, 2009 | 09:16 AM
wevo1985's Avatar
sounds like something might have broken or come apart in the trans. you say all the other gears work well?
Old Sep 7, 2009 | 09:20 AM
Evo8luva's Avatar
This just happened out of nowhere?? Or clutch install? Reverse doughnuts...? Anything..?
Old Sep 7, 2009 | 09:29 AM
pensport's Avatar
yeah all others gears work fine...
Old Sep 7, 2009 | 09:35 AM
evo unknown's Avatar
did u just do a clutch replacement? or how many miles are on the currect clutch? sounds like something internal unless u just did a replacement incorrectly.
Old Sep 7, 2009 | 09:37 AM
pensport's Avatar
the clutch was replaced last yr.. i had some issues where the shifter would get stuck in reverse and had to use force to get it out of gear
Old Sep 7, 2009 | 09:53 AM
wevo1985's Avatar
sounds like something happened to the reverse idler gear. its the gear that only reverse has to make everything turn the opposite way of the engine.
mrmiller
Jun 21, 2016 07:08 PM
noenoe_pro
Jun 13, 2011 01:46 PM
docrog
Sep 6, 2008 06:44 AM
Aikido
Apr 8, 2006 03:13 PM
TheBigLubinsky
Apr 29, 2005 04:47 PM
