Going back to single disc setup instead of twin what will i need?
Old Sep 13, 2009 | 12:41 PM
BoostWhore's Avatar
I bought my car w a carbonetics twin in it. Im going back to a act single what will I need im thinking the rod for the slave cylinder.
Flywheel and maybe flywheel bolts and pressure plate bolts or do they come with the clutch kit?
Before anyone flames why I would go back to a single, I cannot stand the noise created by the twin disc, and I do not drag race the car.
Old Sep 13, 2009 | 12:55 PM
precisionpsi9's Avatar
you goin to need the rod for the slave, pressure plate bolts (6), throw-out bearing, i dont know if they toke the springs out in the trans for the folk (2) they r two different part # too. that about it i think i just switch from carbon clutch to act to and that what i needed
Old Sep 13, 2009 | 12:58 PM
brokenRS's Avatar
My QM is too much for street driving, i will most likely switch back to a single disk or something smoother in the near future.
Old Sep 13, 2009 | 01:17 PM
BoostWhore's Avatar
Mine still uses the stock fork... not sure either.. do u have the part numbers for any of the stuff you had to get the pressure plate bolts and those springs? thanks
Old Oct 8, 2009 | 02:51 PM
kijima's Avatar
We've had good success with the Ralliart 1,245kg pressure plate and standard clutch disc.
TeachersEvo
Jul 11, 2016 10:51 AM
2006GSR
20
Dec 28, 2014 04:23 AM
Dolfandrus
10
Sep 12, 2011 08:05 PM
EndlessRed
18
Mar 18, 2010 07:23 PM
Peteypab2133
Aug 18, 2006 08:28 AM
