Choking at high boost
Old Sep 14, 2009 | 08:52 PM
krypt952's Avatar
I just installedexhaust headers O2 housing evo 9 turbo Fp 18psi wastegate and a test pipe this last wekend, the car has way more power but at hightower boost the engine is choking/poping kinda sounds like a back fire but there's a loss of power only for a split second. It used to do this with my previous setup but now it's doing it way more. I was thinking that maby my fuel pump can't handle it cuz it kinda feels like a slight fuel cut , I am not running a boostcontroller could this also be my problem?
Thanks for the help
Aaron
Old Sep 14, 2009 | 08:54 PM
whoang40's Avatar
You're going to need a tune after all those parts installed. I'd lay off the throttle until you look at the A/F ratio with a wideband or go to your local tuner.
Old Sep 14, 2009 | 08:59 PM
evo unknown's Avatar
u def need a tune. for one reason, u upgraded a turbo. although it is still an oem turbo, it is slightly larger and therefore tuned different for a stock evo 9 ecu compared to ur evo 8 ecu.
the exhaust should not affect it that much? what other mods do u have? turbo back exhaust?
u shouldn't need a fuel pump when just changing to the 9 turbo. however, u definately need a tune. i would advise taking it easy until u get it.
Old Sep 14, 2009 | 09:05 PM
krypt952's Avatar
Alright I wa gonna insall some 272 cams this weekend and get it tuned next week I haven't really been pushing the car just making sure ther were no leaks or major problems, should I get a NBC before I et it tuned or is tht not nessicary?
cij911's Avatar
Since you're in Corona, call Alfred at Tuning Technologies....
Old Sep 14, 2009 | 09:07 PM
krypt952's Avatar
Yup he's the one who's doing my tuning
Old Sep 14, 2009 | 09:23 PM
buchnerj's Avatar
A tune is definitely needed. Are there any problems on the lower end or are they just at max boost? I would get a boost controller too, you can turn up the juice a little bit and it will be even better after you get the tune on there.
Old Sep 14, 2009 | 09:32 PM
sparky's Avatar
Originally Posted by krypt952
.... at hightower boost the engine is choking/poping kinda sounds like a back fire but there's a loss of power only for a split second.
You are most likely experiencing fuel cut. Like the others advise...get a tune!
norlanrodriguez
Dec 16, 2012 08:24 PM
evo4life94
Sep 11, 2012 03:28 PM
ArchieBabes
May 21, 2008 03:01 PM
Kelspar
Jul 1, 2005 08:55 PM
eze
Australian Forum
Mar 31, 2004 03:14 AM
