View Poll Results: hks bov or greddy bov
hks bov
95
45.24%
greddy bov
115
54.76%
Voters: 210. You may not vote on this poll
hks bov or greddy type-s
Originally Posted by EVOPrincess
Every evo owner has a greddy type S its pretty played out
There is also the new Type RS:
https://www.evolutionm.net/forums/sh...d.php?t=112539
The Greddy Type-S is one of he best bovs for the Evo 8 (especially after the "one spring mod") Thats the reason why most Evo owners have it. I myslef was considering an HKS ver. 2 Evo specific SSBOV kit.. but I dont think over al that its gonna be any better than the Greddy.. well.. except maybe the sound. Im just trying to get a video of some sort to get a good idea of how the Greddy sounds.
-Gary
-Gary
Originally Posted by 93civEJ1
this is true, but recirculating is any setup.....just as long as you send the released air from the BOV, back into the intake tract!....for VTA....it is again any setup......Heck, we could even make the stock BOV a VTA...we would just have to disconnect and plug the hose coming off the stock BOV, hmmmmmmmmm.....has anyone tried this??? seems like surely someone has???
The Type S BOV does have a cool sound. Unfortunately its a piece of junk. After time and wear it starts leaking boost. its up to u in the end but between those two id go with the HKS although i dont like the PIEW sound i like the BLITZ i have 2 of them on my supra.
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Originally Posted by sevensign
I would suggest to use HKS SSQV for VTA...its uses two small n big springs to release that air, mine car running VTA rite now n have no stalling problem, its just a matter of self adjustment to the tension spring to ur driving needs, i've posted one topic on the HKS adjustment setting when VTA. But in the near future i'm gonna try recycle the vented air back to the intake...see how the car responds.
*Another fact dat i want to recircle it back to the intake because theoritically when high press air is vente
d to low press at sudden & thru small opening, the air is very much colder, therefore give that little extra cool to the turbo turbine*
Offcourse VTA will run ur car at rich, u can see that if u have A/F ratio meter setup ( Autometer gauges )
http://www.gadgetseller.com/gauges/g...2darkpopup.jpg
HKS SSQV a way to go
nice sound too
nice sound too Last edited by DBallz; Jan 1, 2005 at 11:37 AM.
Originally Posted by blackevoVII
greddy-s.
Compromise: APS BOv
No flutter in 5th gear and releasing gas - no ghey nintendo noises
70 bucks more expensive..
Compromise: APS BOv
as for the type s.....i'm assuming there's alot of flutter on that one?......
i, too am lookin for a bov....and lookin for stock MR BOV....but was really interested in the APS unit....
any extra light shed on this would be greatly appreciated.....thanks
yes the greddy is a pos.. it starts to leak after a while even after the one spring mod.. and it leaks bad after 27psi even if you tighten it all the way
tial and hks are the better choices.. ive also owned the tial and i now have the hks
Originally Posted by nchirico
Anyone have the tial? How does is sound and does it leak past say 25psi? Ive been looking into this one although i have never heard it.
I had the tial too.. one of the best.... it sounds great and never leaked on me even on 34psi... great bov
I have the HKS now.. It flutters a bit, but vents when I want it to after adjusting the primary spring tension slightly.
Its OBSCENELY loud, personally I don't like the sound, but its the ONLY BOV I've tried so far that hasn't eventually started leaking.
There is one problem with aftermarket BOV's.. It takes a long time to adjust them, if they don't vent adequately at part throttle shifts, and your producing boost, it won't vent enough air and you may get RPM's climbing between shifts, or compressor surge..
I have a blowthrough MAF so I am currently VTA, I will run the recirculation pipe back to the intake when I get the recirc fitting for the HKS.. Also I can easily swap between the blowthrough setup, or put the stock MAF back on in a few minutes, so I need it to recirculate.
I don't get it with you guys and that sound.. I personally thing it sounds terribl, I can deal with the fluttering since EVERY DV/BOV flutters, you just can't hear them all the time...
I red the ancient portion of this thread, and wanted to point out the Blitz BOV WILL NOT HOLD BOOST OVER 22PSI No matter WHAT you do.. Heavy spring, shims, etc.. if you put the heavy spring in, you get bad compressor surge, PLUS it doesn't vent enough air volume between shifts when its wide open and venting.
The greddy will begin to leak eventually.. either the spring becomes weakened, or the diaphragm begins to tear.. I don't recommend it.
If you don't want any hassles, leave the damn thing stock, the stock BOV will hold to 21psi for the most part, but it begins to leak as it gets older, (Mine split open at a glued seam)
thats what i have in mine and have no leaks
www.blowoffvalves.com has a few sound clips. the type s is the best quality sound file on there too.
