I have a WEAK EVO !!!!!
Old Oct 18, 2003 | 06:09 PM
Daveyd's Avatar
I have an Autometer gauge and mine reads 20-21 VAC when idle and peak boosts between 17-19 depending on what gear I am in
Old Oct 19, 2003 | 11:28 AM
QuantumEVO's Avatar
Autometer boost gauges are notorious for being off; depending on your sample of the lot. Don't assume your car is weak because a discount gauge tells you so. Check the level when the car is off, first. It should sit at dead zero. Even if it does, the Autometers have been tested to be off up in the higher range.
Mark
www.Quantum-Racing.com
Old Oct 19, 2003 | 11:52 AM
Thoe99's Avatar
Originally posted by umiami80
vERY simple fix, I had the same exact problem. The stock IC clamps are not tight enough and leak out, just open your hood, take off your stock Ram air intake, and tighten all the clamps you see as tight as you can, wala, 19psi.
Is that so? I'm also not hitting 19psi. I did only once in my 4 months of ownership.
Old Oct 19, 2003 | 11:59 AM
BTRTURBOCHARGED's Avatar
i believe the correct term is voila!
Old Oct 19, 2003 | 12:23 PM
chronohunter's Avatar
Presto!!!
Old Oct 19, 2003 | 12:44 PM
90GSX-03EVO's Avatar
Voila!
Old Oct 19, 2003 | 08:15 PM
umiami80's Avatar
That simple it really was teh answer for me.
Old Oct 19, 2003 | 11:57 PM
Noize's Avatar
EvoM Administrator
I posted in another thread that my Autometer gauge zeroes out just under the zero box. Autometer blows. I'm chucking this POS and getting an Omori. I show 16psi peak and 14-15 hold. A couple of days ago, when it zeroed out correctly, it would hit 19psi.
I'm afraid to trust this cheap POS gauge to turn up the boost on my $30,000 car.
Omori gauges, here I come. I had Omori before, but thought I could get away cheap this time. I'm an idiot. Thumbs down Autometer!
Old Oct 20, 2003 | 05:32 AM
ShapeGSX's Avatar
Re: I have a WEAK EVO !!!!!
Originally posted by ytsejam
sup all:
i am jealous at those who're boosting 19 PSI or more peak.
I don't care about anything you said. I just like your username.
November 11th!
eisnikesb
Jul 7, 2014 07:44 PM
kt411gcn
Evo X Dyno Results
Nov 14, 2011 05:26 PM
worksevo89
18
Sep 7, 2008 03:56 PM
electr0
38
Aug 16, 2005 03:39 AM
batty
Jul 25, 2004 01:21 PM
