please help
Old Oct 3, 2009 | 10:28 PM
street56's Avatar
please help
hi , i own a evo8
built 2.0 with hks pistons , oliver rods , stock crank , acl bearings
pnp head with springs , retainers , oversized valves and cosworth m2 cams
buschur racing gt37r turbo kit
hks intercooler kit
ams intake manifold
sparktech COP CDI system
AEM EMS
intercooler piping kit
br double pumper
skunk2 thorottle body 68mm
the car was absolutely fine but now it has started to misfire as soon as the boost hits even at 1bar just on the WG spring . checked the ignition system , ok
checked the plugs , ok . injectors checked . compression checked .afr's ok . cant seem to understand the problem . can you please help me . is there a sensor problem or something ? what what things should i check
i changed the thottle body a few days ago to a skunk2 68mm one and when i changed it back to the stock one , the missing lessened quite a lot but it hasnt finished :S confused . please help . why would missing decrease from putting the stock thorottle body back on?
Old Oct 3, 2009 | 10:46 PM
chaotichoax's Avatar
well the skunk2 throttle body is a hunk of junk and leaks so that explains that
was it fine before you messed with the throttle body to begin with?
Old Oct 4, 2009 | 02:51 AM
street56's Avatar
it was fine before the double pumper install and the TB . but i dont think it has anyhing to do with the double pumper . now im back on the stock TB but the missing is still there .. its lessened a lot but sill there
Old Oct 4, 2009 | 02:58 AM
churbo's Avatar
Probably have a leak somewhere. Double check your work. How long has it been since the plugs were replaced?
Old Oct 4, 2009 | 09:40 AM
street56's Avatar
plugs just changed two times
Old Oct 4, 2009 | 04:16 PM
cssaddictm4's Avatar
Were you retuned after thre double pumper install?
Old Oct 5, 2009 | 11:08 AM
street56's Avatar
yeah i leaned it out a it started running in the high 10's afr
Old Oct 5, 2009 | 11:17 AM
Evo8motorS's Avatar
does it missfire only when you hit 1 bar (when you are in the boost ) or even you deceleration ?
could be a vaccum leak
Old Oct 5, 2009 | 09:46 PM
street56's Avatar
it only misfires when you hit full boost . 1 bar 14psi . oherwise its perfectly fine
Old Oct 11, 2009 | 03:47 AM
street56's Avatar
bump
coffeemama
64
Jul 26, 2024 05:32 PM
georg1970
50
Dec 20, 2021 03:19 AM
Brianawd
Oct 25, 2012 04:30 PM
evoiao
May 7, 2012 07:53 AM
makspeed
Dec 2, 2010 06:37 PM
