How many of you live with all 3 ACD lights?
Old Oct 9, 2009 | 05:02 AM
black95tt's Avatar
And what disadvantages have you noticed, other than the lights being on of course? How long have you driven with them on?
Mine have been on since I bought the car, the owner said they were on for him for about 15k miles. So far nothing bad has happened. I think the center diff does default to an open diff configuration. My car will sometimes spin the front wheels pretty badly in the rain, even in a straight line. If my understanding is correct, the center diff should be locked at that point not allowing that to happen. What are some others experiences?
Old Oct 9, 2009 | 05:24 AM
tkklemann's Avatar
I lived with it for awhile, but finally told myself I was going to fix it finally. It was only a broken wire close to the fuse box on the Drivers Side Engine Bay. Don't know how it got severed though.
The Factory Service Manual has a great write up on how to diagnose it, its simple and easy. The only bad thing is it might lead you into finding out your pump is bad, and that's a heck of a costly pump. You might find, like I did, its only a severed wire and get *lucky*..
Try diagnosing it if you haven't...
Old Oct 9, 2009 | 05:27 AM
CAD EVO's Avatar
Ive had mine on for 20k and it pisses me off everytime I get to the end of my street. Mitsu diagnosed mine as a bad pump.
Old Oct 9, 2009 | 06:28 AM
KevinD's Avatar
just a question, did you try bleeding the system to see if thats the issue? very likely during a clutch install someone didn't know how to bleed it and just left it. the lights will come on if there is air in the system.
Old Oct 9, 2009 | 06:39 AM
scheides's Avatar
EvoM Moderator
Mine's been on for months, I finally broke down and bled it the last two nights. It was WAY easier than I thought it was going to be!
I'll report back, but otherwise used pump may be my only option...how much are they from the dealer? Anyone know anyone that can rebuild them?
Old Oct 9, 2009 | 06:53 AM
black95tt's Avatar
Have not tried bleeding. The previous owner did say that it was bled after the clutch was installed. He was aware of the matter and did what he could to correct it.
A new pump is thousands of dollars from the dealer. I've seen them for ~$300 used on here. But what is going to stop it from failing as your factory one did? They appear to all fail at some point. I don't think it's the mechanicals of the pump, but more an electrical issue. Hydraulic pumps are pretty solid, they don't just go bad all of the sudden.
Has anybody noticed anything different when driving the car performance wise?
Old Oct 9, 2009 | 07:06 AM
8thWonder's Avatar
Mine come on periodically. I haven't noticed any loss in performance at all, usually when the temps drop.
Old Oct 9, 2009 | 07:15 AM
fugiwara's Avatar
Question
how do you know there is nothing else wrong with your ACD?
Old Oct 9, 2009 | 07:23 AM
black95tt's Avatar
^ I would imagine the lights went back to normal, so what else there?
Old Oct 9, 2009 | 10:04 AM
l2r99gst's Avatar
MN168621 - hydraulic unit - MSRP is $2,148.33
I would say that you should use your warranty to get a defective pump replaced...that's a ton of money for that part.
I had all 3 ACD lights on as well...took it to the dealer, diagnosed as a bad pump and replaced under warranty. Mileage was around 32,000 I think.
Old Oct 9, 2009 | 01:39 PM
evo003's Avatar
Had the same thing and got my pump replaced under warranty. No more lights.
Old Oct 10, 2009 | 07:54 AM
EvolNinja's Avatar
I've been driving mine for months too. I tried bleeding the sucker a couple times and it still comes. Whenever I start her up and rev or give a little gas, the pump would come on and after it stop, all lights lit up. Hate it but don't know what to do. I plan on driving it until it goes out and maybe swap it to the 03 version that don't have the ACD?
Old Oct 10, 2009 | 08:16 AM
justa4banger's Avatar
Mine ain't on...but when my pump messes up ima go wit a 03 transfercase and ima get rif of that heavy *** acd pump
Old Oct 10, 2009 | 08:18 AM
silver9mr's Avatar
mine only comes on when its very hott out side
Old Oct 10, 2009 | 11:41 AM
Driveteam's Avatar
I had this. It ended up being the rear passenger brake sensor. Appearantly the circuits are all connected somehow. We did on ohm test all the way around and found the one bad sensor. Replaced it and the lights have worked properly ever since.
Mauricio Evo IV
28
Feb 28, 2016 04:34 PM
JebusMKIV
96
Nov 19, 2011 05:12 AM
hawaiian_evo
10
May 7, 2008 03:45 AM
QwikEVO
15
Jun 29, 2006 12:43 PM
redevo8driver
Dec 22, 2005 08:44 PM
