View Poll Results: what would you do with your water pump?
leave it and change it at 120k miles
11
35.48%
change it at 60k miles
19
61.29%
other - please specify
3.23%
Voters: 31. You may not vote on this poll
60k miles water pump: keep or change?
Old Oct 16, 2009 | 01:15 PM
jxs1984's Avatar
i need to do my timing belt and im wondering if i should change the water pump or leave it and change it at 120k miles? this is my daily driver and it doesn't see track much... just a couple races at the drag strip and some highway pulls.
Old Oct 16, 2009 | 01:16 PM
Ginglingston11's Avatar
if your doing the tbelt then you might as well. besides its recomended every 60k
Old Oct 16, 2009 | 01:21 PM
TalonTuner4G63's Avatar
If your doing the job yourself and don't mind having to go through it later if it fails, it's up to you. If your paying somebody to do it, have it replaced.
TheDream's Avatar
You don't have to do water pump. You can for simple insurance, however most last up over 100k.
Old Oct 16, 2009 | 01:24 PM
TxEvo8's Avatar
I opted not to do it at 60k, and my pump didn't last until 120k. At 100k, mine let go while on my way home for xmas. I had to have the car towed home and then hop a flight to Houston for the holidays. I will not make that mistake again...
Old Oct 16, 2009 | 01:31 PM
SBR INC's Avatar
it's right there when you're preforming the service. It's not very expensive and easy to replace once it's all part. it's worth the piece of mind to do it. That's why i make them standard in all of our timing kits. No reason not to do it.
Old Oct 16, 2009 | 01:37 PM
jxs1984's Avatar
thanks for your inputs
Old Oct 16, 2009 | 01:41 PM
SBR INC's Avatar
good luck, buddy!
Old Oct 16, 2009 | 02:11 PM
Thomasevo's Avatar
if your in there already you might want to change it but worse case it fails your car runs a little hot you notice it shut it down and then replace. Best case scenario you never have a problem seems a little senseless to spend the money on a new pump buy your car something else it will appreciate it more.
Old Oct 16, 2009 | 02:52 PM
awd2gen's Avatar
Do the waterpump it's worth it to spend the money and do it now when it will only take you 5 extra minutes and get you alot better reassurance.
Old Oct 16, 2009 | 02:54 PM
GgreyEVOIX's Avatar
Doh! I wish I saw this thread before I replaced my belt.
Old Oct 16, 2009 | 02:57 PM
buchnerj's Avatar
You might as well, your already in there. No sense in waiting for it to go, when then you might really need the car, or as someone stated above, be somewhere far from home. Preventative maintenance on these cars is key to saving money and time in the long run...
Old Oct 16, 2009 | 08:06 PM
vtrice69's Avatar
just do it, make urself feel better when you're driving it or you'll be dreaming about it at night.
DEA
Jun 15, 2015 08:11 AM
oneofakindracer
13
Apr 14, 2010 07:19 AM
symX
Lancer Engine Tech
13
Jan 5, 2010 04:09 PM
jdmtim
13
Oct 7, 2008 07:13 AM
evoryne
Jan 30, 2008 12:09 PM
