Wideband readings.....
Old Oct 20, 2009 | 07:32 PM
97TSiAWD's Avatar
Originally Posted by RSMike
In New Zealand there is 91, 95 and 98 Octane. most people tune on 98.
I'll be tuning my car for about 12.0 - 12.2 AFR when i get my Red from the states.
We leaned up a standard evo 8, from about 11.0 to 12.0 and picked up 30kwatw (40whp) without touching anything else. Running 98 Octane pump gas.
Yeah, I have no doubt that running it leaner will make more power. I think that people (including myself) tend to tune it at a safer level on pump gas rather than going for all out power.
And, of course, a lot of people like to run higher boost than where the turbo is most efficient causing increased heat and a higher tendency to knock. So, they end up running higher boost, but richen up the A/F and decrease timing to do so.
Old Oct 20, 2009 | 07:35 PM
97TSiAWD's Avatar
Originally Posted by jyndrus90
I did sorta a custom intake since I got a 4in maf adapter and got a small 4 in filter. Should I leave that or put in the stock airbox for correct readings? I got a new bung welded in because my wideband o2 was like 60in from the turbo
You can leave the current intake on as long as you get the car retuned. Pretty much anytime you add power mods or increase the boost, you'll have to retune the car accordingly. And the retune will help you get the most out of those upgraded parts.
If you plan on doing a number of additional mods in the near future, I would get those pieces installed and then have the car tuned. If you are going to tune the car yourself, read for a long time (lots of good resources here), and then make small adjustments and datalog how things change.
Old Oct 20, 2009 | 07:43 PM
TTP Engineering's Avatar
Originally Posted by t-revzr
My car is at 11.1 im on E85 tho not sure if that matters...
So many cars in this thread not tuned correctly...
Old Oct 20, 2009 | 07:46 PM
There are different methods to measure fuel. Most non-US countries do NOT measure fuel octane in RON+MON/2 method which means your advertised octane is much lower than USA 93.
WTFchuck
Feb 18, 2012 08:20 PM
evo4noob
Jul 18, 2010 09:05 AM
def1
Sep 21, 2009 08:33 PM
Talon_66
May 12, 2008 01:07 PM
