After lower intercooler pipe install, problem starts.
Old Oct 22, 2009 | 08:36 PM
hang187's Avatar
I've just put in an ets licp, and whenever I go WOT past 3500 rpm, the car hesitates to pick up anymore speed (like air is having a hard time going through the pipes). But @ 3500 rpm if i keep my foot all the way in, it'll go normal then hesitates again. I checked all clamps and its fine. Any idea?
Old Oct 22, 2009 | 08:41 PM
LuisIX's Avatar
boost leak test the system maybe you have a torn coupler..
Old Oct 22, 2009 | 08:44 PM
gsrboi80's Avatar
I'm guessing boost leak for sure dude. Boost leak test the car
Old Oct 22, 2009 | 08:45 PM
BoostWhore's Avatar
I would guess a leak of some sort lots of times leaks r not visible.
freshevo8's Avatar
1. Has the car been tuned b4? If so, could need a retune as it cold be leaning out.
2. Did you adjust your boost controller after installation to keep your boost levels the same or maybe turn it down 2 psi?
3. Do a boost leak test if you have a leak tester. Here is a good one to keep on hand :
http://www.paradigmperformance.net/p...boostleak.html
I have this one personally and it works great
Old Oct 22, 2009 | 08:50 PM
4G63kevin's Avatar
check for torn couplers like luis said. gl!
Old Oct 22, 2009 | 08:54 PM
hang187's Avatar
thanks for the quick replies! yeah i'll do the boost leak test first. thanks
Old Oct 22, 2009 | 09:35 PM
sysek's Avatar
boost leak
Old Oct 22, 2009 | 09:42 PM
mitsuevodriver's Avatar
How do you do a boost leak test?
Old Oct 23, 2009 | 02:02 PM
evo unknown's Avatar
search boost leak test..you can make a home made one for like $5..
either a small leak around one of the couplers, and then perhaps as the air is still taken in the coupler expands enough to close it.
or..the car is leaning out and therefore cutting back on the air taken in and you may need a tune. all cars react differently to differnt mods. like my mods are in my sig and i am only on an off the shelf map from cobb, i would perform better with a custom tune.
Old Oct 23, 2009 | 02:12 PM
ssg_petty_210's Avatar
try getting a tune with it. my friends did the same thing, but it was because of the larger diameter piping. he was tuned and then it was all good from there
Old Oct 23, 2009 | 04:56 PM
NotAnEvoOwner's Avatar
could be tune, but like everyone said sounds like a torn coupler or boost leak.
Old Oct 23, 2009 | 04:59 PM
ETS Michael's Avatar
I'm thinking it may be a boost leak. Check all the couplers and connections and make sure everything is tight. Building a boost leak tool is the easiest way to find out though.
Thanks!
Michael
Old Oct 23, 2009 | 05:16 PM
cant beat a boost leak test.
bossmangunit
Jan 24, 2016 01:45 PM
boost_dependent
17
Mar 5, 2012 11:09 AM
Mad_SB
20
Apr 10, 2011 03:41 AM
MionieEvo
Dec 26, 2010 01:23 AM
captain150
Dec 18, 2004 10:10 PM
