hks blow off valve
Old Oct 22, 2009 | 09:12 PM
bumblebmo's Avatar
Unhappy hks blow off valve
so i just installed a hks super sequential blow off valve in my 2003 evo 8 and now when i let go of the gas at high rpm and put in nautral my car will die out. i think it might be a vacuum problem but im not sure any ideas?
Old Oct 26, 2009 | 08:36 PM
hang187's Avatar
Are you recirculating or venting to atmosphere? HKS SSQ doen't work very good on an evo. I used to have one and sometime stalls here and there. I got the HKS EIDS and everything was solved. If your all stock the oem bov is fine. but i did it for the sound, runs crappy, went back to oem bov. live and learn
Old Oct 26, 2009 | 08:58 PM
Evo_IX_Guy's Avatar
Do you have it VTA or recirculating? If you VTA then you need to cap off the hole on the air intake where the oem bov was at. Im posting a linking that will show you how to recirculate which should be your best bet.
https://www.evolutionm.net/forums/ev...ating-kit.html
Old Feb 21, 2010 | 08:53 PM
djikonatx's Avatar
same prob....sucks..
Old Feb 21, 2010 | 10:35 PM
96eclipseGST's Avatar
Probably VTA because it sounds sooooo sweet
Old Feb 21, 2010 | 10:41 PM
Brokenevo's Avatar
not a very smart idea to bring the engine to high revs then just put it in neutral, let the engine rev down if your going to do that, your only going to hurt the engine!
Old Feb 21, 2010 | 11:50 PM
ssg_petty_210's Avatar
Well the BOV is def the cause. But if you must have this BOV, and you absolutely have to have it, get the HKS idle stabilizer. It will fix that issue. Some people say it doesnt do nothing and is a quick cover up, but my buddy has the hks ssqv version 2 and had the same issue. We installed the stabilizer and it fixed it. IT DOES WORK.
Old Feb 22, 2010 | 08:27 PM
xtdtxphenomenal's Avatar
i installed the hks ssqv version 3 on my 2003 evo 8 last week and it works fine
Old Feb 25, 2010 | 12:45 PM
SavEVOIX's Avatar
Originally Posted by Speed MR 857
get the HKS idle stabilizer and recirculate it
You can VTA with the stabilizer in though
Old Feb 25, 2010 | 12:49 PM
4g63smokinall4s's Avatar
there are many many threads talking about how the HKS bov is pretty much the worst bov for the evo.. do a search and read some of the material.. there are also many threads asking the same question u asked... use the search button! GL
Old Feb 27, 2010 | 02:04 PM
motorspt's Avatar
oh ricers. Sound = performance.
Old Feb 27, 2010 | 04:10 PM
CJ2X's Avatar
I bought one for my 5. I bought it because everything else in it is HKS, so I figured I couldn't go wrong... Wish I would have done some research first. Now it's just sitting in my closet in the box, brand new...
Old Feb 28, 2010 | 05:42 PM
silkey00's Avatar
i have the same problem.... im switching back to my forge... :-(
Old Mar 2, 2010 | 05:52 AM
jdm93cx's Avatar
why should he not enjoy the sound of his car while going fasT?
Old Mar 5, 2010 | 04:09 PM
evo9801's Avatar
hks is the best sounding one but it doesnt work very well on the evo
