cel for o2s when they work fine?
Old Oct 23, 2009 | 10:01 PM
commandwolf's Avatar
I know this should be in the lancer section but you guys know as well as i do no where near as many people look there as here....
I drive a 03 OZ rally. I purchased and installed a Greddy ti-C cat back approximately 4 months ago. About a month ago my CEL came on. I figured it was a bad o2 sensor and it was. However my mechanic told me that the code was for the o2 sensor and that was what was turning the CEL on but there was nothing actually wrong with the sensor it's self. He thinks it is the back pressure of the catback now that it has been covered in carbon. He said i could replace the o2 sensors to fix the problem so i could pass inspection but more likely then not the CEL problem would just come back. Has anyone encountered this problem before or know a way to fix this permanently with out replacing my cat back?
Thanks
Old Oct 24, 2009 | 06:04 AM
bump
Old Oct 26, 2009 | 04:49 AM
bump
Old Oct 26, 2009 | 05:04 AM
sl0ev0's Avatar
is this the pre-cat sensor or after the cat? have you or you mechanic actually seen the o2 sensor and saw the carbon build up? if it is the one after the cat, you may possibly have a faulty cat. the most probably cause is that the o2 sensor failed just randomly after you installed the exhaust. the car is 6 years old, o2 sensors do go bad on there own. i say just replace the sensor and you probably wont have the problem again
Old Oct 26, 2009 | 07:46 AM
he was telling me that the o2 sensors are working correctly and that he cleaned them but when i left like 10 mins later, after i left,the light came back on .... do you think he is wrong and the o2 is actually broken ? cause i was going to replace them but he seems tot think that replacing them will only be a like putting a bandaide on the problem and it will come back.
Old Oct 26, 2009 | 07:53 AM
xmaciek82x's Avatar
I would try this first for the rear sensor:
https://www.evolutionm.net/forums/ev...ouler-how.html
If it won't fix the o2 cell then your sensors are bad.
MaxxPwr
Apr 13, 2008 08:54 AM
Silverfox742
04-06 Lancer Ralliart How To Requests / Questions / Tips
Jan 12, 2008 10:28 AM
SuperStreet2K6
41
Jun 28, 2007 02:07 AM
yesevo
12
May 16, 2006 11:30 AM
TRDHarrier
15
Dec 15, 2003 07:46 AM
