ses flashing at wot
Old Oct 26, 2009 | 05:06 AM
TTP Engineering's Avatar
Originally Posted by JohnBradley
I see the use of phantom knock needs clarified. Phantom knock is knock that happens intermittently with no other signs of a cause. If it is misfiring and the knocklight is going nuts its a very good sign that the car is actually knocking. This seems to be very repeatable so its not phantom at all.
The P0172 is from injectors that arent scaled correctly and its maxing the trims or close to maxing them generally. Seems to me that it needs the timing dropped and the injectors tweaked.
Good information Aaron. I laugh when I see people writing phantom knock all the time.
Old Oct 26, 2009 | 05:24 AM
MR. EVO MR's Avatar
Originally Posted by evillancer06
I have to get my hands on a air compressor for the boost leak. You guys recommend testing from the compressor or the tb or both?
a bicycle pump works too, why spend the money if you dont have to?
Old Oct 26, 2009 | 06:50 AM
evillancer06's Avatar
Veteran: Navy
ok so if it is real knock, what can i do to eliminate this? I have looked around and seen suggestions of changing plugs, changing actual knock sensor. I just want to know what i can do on my behalf to try and eliminate this. The only thing is i am thinking that its pulling timing and all because of the fluctuation of boost that i have. I think the crazy boost spikes is somehow triggering the pulling of timing. Please correct me if im wrong.
Old Oct 26, 2009 | 06:55 AM
fugiwara's Avatar
What your tuner Jestr say about this?
Old Oct 26, 2009 | 07:56 AM
Veteran: Navy
[img]ses flashing at wot-image.jpg[/img]
here is a dyno graph of one of the runs. Notice on the torque graph the up and down fluctuation. It is due to the boost fluctuation. My ses dont start flashing untill around 6000 rpm. So from what i see boost is fluctuating and ses is flashing all around the same rpm.
Old Oct 26, 2009 | 08:44 AM
Paulito's Avatar
possibly maxing out the stock wastegate???
Old Oct 26, 2009 | 09:43 AM
Veteran: Navy
it is the stock wastegate that comes with the fpred
Veteran: Navy
i am putting down 404. Should i be using 1 step colder plugs or are the stock heat range good enough?
roidz3
Oct 1, 2015 03:53 PM
Jrod@Buschur
Mar 14, 2012 10:05 PM
Chukee_R
17
Jul 2, 2007 02:03 PM
David Buschur
Aug 26, 2005 08:24 AM
David Buschur
56
Aug 24, 2005 09:57 AM
