Code: P0240 Catalyst System Efficiency Below Threshold
Old Oct 27, 2009 | 06:27 PM
Nastynine's Avatar
As title says. my car threw a check engine for the past week
the code was: P0240 Catalyst System Efficiency Below Threshold (bank1)
the cars got 17,800 miles on it and its 100% bone stock nd yeah.. its been running fine.
i cleared the code today, but idk what exactly threw the code.
i understand it could be the o2 sensor or a bad cat. i don't think its the cat.
what should i do? cars still under warrenty should i just let the dealership deal with it?
Old Oct 27, 2009 | 06:29 PM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Have you tuner reflash it with the "force pass" ecu patch code should be gone after that
Old Oct 27, 2009 | 06:30 PM
xRoguex's Avatar
make dealership fix it.. simple.
Old Oct 27, 2009 | 06:34 PM
jester81783's Avatar
since your car is bone stock with a warranty, i wouldnt follow this guys advice. I got the same code as you when i put in my high flow cat, but since you are stock i would keep an eye on it, and if you throw the code again, take it to the dealership, youll probably get a new catalytic converter.
Old Oct 27, 2009 | 06:37 PM
DBallz's Avatar
Yeah if it's under warrenty have the dealer check it out if you don't want the hassle just have someone flash on the OBD force pass.
Old Oct 28, 2009 | 10:41 AM
Nastynine's Avatar
goddddamnit. the code came back today. im gunna stick a fouler in the o2 sensor and see what that does. if not im gunna just take it to the dealer. i was trying to avoid that though
Old Oct 28, 2009 | 12:12 PM
dastallion951's Avatar
is ur car bone stock? dont be retarded and put an 02 sensor fix in it if it has that cat converter on the car...do like they said and go to the dealer let them fix it for free......
Old Oct 28, 2009 | 12:31 PM
NOMIEZVR4's Avatar
Best thing to do is take it to a dealer and see what they say. Since you do have warranty they will check it for free but if it is the 02 sensor they prob wont cover it but hey that way you will know exactly what it is.
Old Oct 29, 2009 | 09:24 PM
Nastynine's Avatar
why wont they cover it if its an o2 sensor? full powertrain warrenty o2 sensor isn't under warrenty?
Old Oct 29, 2009 | 09:26 PM
Nastynine's Avatar
also if it is the cat, i could give a crap less cuz im going catless in a week or so
ExtremeDSM
14
Feb 23, 2012 06:40 AM
WisemanWV
Lancer Troubleshooting
23
Oct 20, 2010 07:36 PM
jacfumo
Feb 4, 2010 12:14 AM
cRc`22
Apr 14, 2009 01:59 PM
RumbleCam
May 2, 2005 10:12 PM
