MBC users thoughts?
Old Nov 5, 2009 | 10:12 AM
Kracka's Avatar
Originally Posted by Ginglingston11
thats the first time i have ever heard of that
Search around, its been discussed many times over in the ECUFlash section of the board.
Old Nov 5, 2009 | 10:21 AM
mt057's Avatar
I love my ebc. I can quickly adjust boost from sunday drive to kill. I also have a fail safe for my meth kit tied in that drops boost to wastegate on low/no flow. I find that it holds boost very well.
Old Nov 5, 2009 | 10:28 AM
xceler8rob's Avatar
Mbc is a cheap effective way to go. I'm switching over to GM 3 port ecu controlled. Remember you get what you pay for. I'd rather have something constantly monitoring and controlling my boost for me based on the parameters I setup rather than relying on some spring to do it's job.
Old Nov 5, 2009 | 10:35 AM
bryanole27's Avatar
Never owned an EBC, but I absolutely love my AMS MBC.
Old Nov 5, 2009 | 10:37 AM
SyZyGy1394's Avatar
Originally Posted by FJF
Much of the cold weather spiking is due to the spring inside the MBC changing its response as the metal gets colder. My MBC is mounted to the radiator. As the rad comes up to temp, so does the MBC. As such, I see little variance in boost levels - ~.5PSI from 30F-90F according to my logs. FWIW, I can't take credit for the idea. Em, from STM, installed it in that location for this very reason and he was right.
Yeah mine is mounted right on top of the right side of my radiator. I guess I should just stay out of boost for a little longer till my engine bay gets even hotter.
Old Nov 5, 2009 | 10:39 AM
FJF's Avatar
FJF
I stay out of boost until the oil is up to temp.
Old Nov 5, 2009 | 11:41 AM
BLKCarbonEVO's Avatar
If you have a 3port call Bryan at GST and say "give me the smarts" Ecu controlled Boost is great with v7. It has a larger map and gear based boost control
Mikey
Old Nov 5, 2009 | 12:25 PM
SyZyGy1394's Avatar
Yea I'll just wait more now because its getting colder. Heck I don't even move the car for at least a minute and then after that I baby it big time.
Old Nov 5, 2009 | 12:29 PM
cubantexan's Avatar
Easy peasy lemon squeezy. Oh and cheap too.
Old Nov 5, 2009 | 05:59 PM
adWRXi's Avatar
ive never had either. but i would say a mbc is sufficient.
Old Nov 6, 2009 | 09:19 AM
OneEyedJack's Avatar
I have MBC mounted to the radiator. Just don't go ape on it right at startup... hell you shouldn't do that to any car!!
It's working great for me.
Why the hate on the little spring!? Even solenoid valves have a spring keeping it shut! You just have a bunch of copper and some spiffy electrons to pull it open instead of pressure hehe
Old Nov 6, 2009 | 09:23 AM
Bggstin's Avatar
Step 1. Buy an MBC
Step 2. If don't have an EBC continue to step 5.
Step 3. Remove EBC and install MBC.
Step 4. Smash EBC with a hammer.
Step 5. Install MBC.
Step 6. Enjoy you're car running correctly under load and WOT.
Old Nov 6, 2009 | 09:40 AM
CleverUserName's Avatar
https://www.evolutionm.net/forums/ec...ecu-boost.html
https://www.evolutionm.net/forums/ec...-solenoid.html
https://www.evolutionm.net/forums/ev...led-boost.html
paid 60 bucks for my 3 port. my mbc is for sale...
Old Nov 6, 2009 | 10:13 AM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Interesting debate I must say.
          I will be selling my Blitz SBC-ID EBC and installing my GrimmSpeed EBCS and Omni 4 bar Map sensor in the new year with Tephra V7 patch
          Old Nov 7, 2009 | 11:04 AM
          Ted B's Avatar
          Originally Posted by Kracka
          I noticed the exact opposite on my car.
          That can be the case if one has his EBC programmed such that it is active prematurely. The idea in programming an EBC is to keep the solenoid closed until just before the point where boost needs to be controlled. If it is clicking along in unboosted regions, this will delay spool to some degree, especially where an unecessarily weak WG spring is used.
          The limitation in the solenoid duty vs. rpm table is the onset of boost vs. rpm is different in different gears. This is where either load limiting or pressure limiting boost control strategies prove their worth.
