Boost Creep
Old Nov 11, 2009 | 06:13 PM
3gEclipseTurbo's Avatar
Boost Creep
Ok so the internal wastgate is 10psi, which i will get untill 4k ish and then it shoots to 15psi and will slowly raise over that untill redline. I thought maybe the wastegate opening was too small so i ported it, as much as possible. But it didnt help. I checked and i cant find and vacuum leaks and my boost gauge is showing perfect vacuum, idk? What else can be causing this? A bad wastegate actuator? But why would it hold at 10psi to the same rpm then creep up if it was the actuator. Any suggestions? Im suppose to be goin on the dyno friday, i need to get this fixed asap!
Old Nov 11, 2009 | 06:41 PM
X91EVO's Avatar
Registered User
I would just say to check all your vacuum lines again
Old Nov 11, 2009 | 06:47 PM
Thats what i keep thinking but after the 20th time going over the lines, i doubt theres a vac leak and if there is i must be blind but just for the hell of it im gonna have my friend look them over. It always seems that he finds the whats wrong with my car. like the time i blew up a coupler and thought i blew my motor lol.
Old Nov 11, 2009 | 10:58 PM
What else can cause boost creep besides, vac leak and too small wastegate/opening?
Old Nov 12, 2009 | 06:32 AM
97TSiAWD's Avatar
Running too little boost. What kind of turbo is this?
Old Nov 12, 2009 | 10:27 AM
16g. now that you mention that when i had my boost controller in i had it set to 15psi and it stayed right there maybe went to 15.5psi. But then i took the mbc out, got a vac leak and fixed it, installed a new bov then this started happening. But i broke my mbc so i cant test that untill my new one comes in.
Old Nov 15, 2009 | 02:54 PM
i switched wastegate actuators but im still having a prob. When i go wot ill hit 15psi go down to 10psi then comeback to 15psi. I know its not the wastegate actuator and its not the mbc as ive tryed 3 differnt actuators and 2 mbc
Old Dec 9, 2009 | 06:25 PM
detroit pistins's Avatar
did u up solving this issue? i amhaving somewhat of a similiar one and sort of stuck with no answer either.
Old Dec 9, 2009 | 06:51 PM
It turned out to be the port job that the kid did that i bought the turbo from. Not the wastegate opening but the inside of the exhaust housing. I turned up the boost to 17psi and no creep at all, just had to be above 15psi where it would jump up to then creep from there. Was the turbo ported?
Old Dec 9, 2009 | 06:56 PM
I have a ported ex manni, o2 dump, intake, exhaust, and a hallman mbc.
haven;t tuned it yet or anything, just trying to atleast set up the boost so it wont creep over 1.5 bar, and it seems to be hitting 1 bar then slowly creeps over 1.5 and that's when i let go.
I turned the hallman all the way down, and it still hits over 1.5 in 4th gear.
checked and made sure the mbc lines are connected correctly. checked the interior of the mbc for any dirt build up or what not, and everything seems fine.
its on a stock turbo, with a stock flapper and hotside. not sure what else to check.
but i did notice that the flapper inside the hotside has a longer travel range when its not connected to the actuator's arm vs. when it is connected to it.
EVO8LTW
30
Oct 29, 2018 03:17 AM
06rallyred
Sep 4, 2014 09:30 AM
MRpunk
Jan 29, 2012 09:28 PM
eag36
27
Dec 9, 2009 07:06 PM
Appauldd
Jan 26, 2009 05:13 AM
