Clutch gone at 16k- Need recommendations
Old Dec 21, 2009 | 08:34 PM
  #91
Protostar1's Avatar
Can someone explain where the clutch line 'pill' is and should it be replaced when an SS line is used?
Old Dec 21, 2009 | 08:50 PM
  #92
Jeff_Jeske's Avatar
Its up by the slave cyl.... but... I wouldn't remove this pill unless you have flawless footwork. There is NO REASON to remove it.
Old Dec 22, 2009 | 08:19 AM
  #93
Protostar1's Avatar
Well... now that you mention it... my footwork is flawless Is it literally a bean type thing that sits in the line? As in will it be obvious when I switch the lines out or will this be some tiny piece I loose... Thanks!
Old Dec 22, 2009 | 09:47 AM
  #94
BBS's Avatar
BBS
Originally Posted by Protostar1
I would have thought the same until another member on here recently posted his clutch swap and said he spent about $30 on OEM replacement gaskets... for something. I was not thinking there would be anything and I guess if you are saying there are no gaskets, it is a non issue for me. Thanks!
Maybe he replaced his axle seals when he did the job which isnt a very bad idea at all.
Old Dec 22, 2009 | 01:34 PM
  #95
sk8terdude929's Avatar
Originally Posted by R/TErnie
Exedy twin HD - Cerametallic.
I would get the SS line and remove the hydaulic restrictor
I would also buy the STM slave cylinder stopper
Optionals... shifter bushings and front engine mount.
I've got amost 10k miles on my twin and I've got around 10 passes at the strip. I love it.
R/TErnie is the advantage of the STM slave cylinder stopper??
Old Dec 22, 2009 | 11:30 PM
  #96
Protostar1's Avatar
I am definitely getting a fork stop given they are $90 well spent to prevent pulling the trans in the event of the fork overreturning and popping the TOB clip loose... I personally like MAPerformance's more than DTMs but it is more expensive.
Old Dec 22, 2009 | 11:31 PM
  #97
Protostar1's Avatar
Is that an inner seal on the ends of the axle or are you saying replacing the boots over the CVs? My car has so few miles, I would think the seals and gaskets can't be in too bad of shape.
Old Dec 28, 2009 | 09:20 AM
  #98
ChrisCarey's Avatar
What is the pricing of the DTM unit? I'm sure we can work with you sir, just shoot me a PM
Old Dec 31, 2009 | 10:32 AM
  #99
Mbernhardt's Avatar
Exedy hyper twin! prolly best for the money. Since you get what you pay for! or an OS giken...still pricey though! :P
Old Feb 24, 2010 | 05:40 AM
  #100
VGergo's Avatar
Hello,
What do you think with the stock power evo can I re-use the oem Pressure Plate and just replace the disc with a new one with 15k miles in ? if the surface of the Pressure Plate find will work well with the new disc ?
BoostedAWD91
22
May 5, 2013 06:59 PM
raytrix
Dec 2, 2012 08:00 PM
fireroasted
Sep 16, 2012 08:08 AM
Protostar1
29
Aug 3, 2011 04:31 PM
wojo
For Sale - Cars For Sale
Jul 27, 2007 06:50 PM
