When oil pump leak!
Old Nov 14, 2009 | 07:32 PM
travail's Avatar
When oil pump leak!
Well my oil pump was leaking out of oil pump gear on the timing belt side. Has any one seen this before. Because it looks like the oil pump gear was rubbing on the inside of the case and it looks like the oil pump case cover needs a gasket.. Here are some pics
Old Nov 14, 2009 | 07:40 PM
Ev0ikon's Avatar
I would say major contaminants. Did you removed the Balance Shafts?
Old Nov 14, 2009 | 07:43 PM
travail's Avatar
Both balance shafts have been removed and there is a stub shaft on the upper oil pump gear. When I put together the new oil pump the gear's are hard to turn. But when I loosen the nut's just a little it spins good no drag. This came off and motor with 2000 miles on it.
Old Nov 14, 2009 | 07:51 PM
Ev0ikon's Avatar
I did the same. I hope mine won't get that bad. How long did you have it back since the last rebuild?
There are some rather large threads about this problem and most blamed it on stub shaft. But there are also thousands of engines that run them without problem.
Old Nov 14, 2009 | 08:53 PM
TTP Engineering's Avatar
Replace the whole frontcase. $220
Old Nov 14, 2009 | 11:38 PM
travail's Avatar
I have a new case and I got it for $190 new with shipping.
Old Nov 15, 2009 | 05:51 PM
barneyb's Avatar
It sounds like you are good to go. Just make sure you get the timing belt adjusted correctly - so the grenade pin is still loose after it has sat awhile.
travail
Jul 15, 2010 09:58 AM
travail
11
Apr 15, 2010 12:27 AM
travail
11
Jan 29, 2010 05:33 AM
travail
18
Jan 27, 2010 03:35 PM
