Early EVO Christmas
Early EVO Christmas
Thanks to the ER crew for taking good care of their customers, I'm finally starting to see some progress getting my car back together after it throwing a rod: https://www.evolutionm.net/forums/ev...k-carnage.html
Johnny I see that your going with a 4g64. I plan on doing the same and I have ben trying to research everything. Which oil pump did you use the 4g64 one or the 63 ? Also the same thing with the water pump which one do you need to use ?
Thanks Jeremy
Thanks Jeremy
4g63 Oil Pump
4g63 Water Pump.
The water Pump needs to be modified to cover an open spot in the block. Two spots on the pump gasket surface needs to be built up, and then machined flat.
John-
4g63 Water Pump.
John-
maperformance
Jul 1, 2010 10:20 AM
