How much power will my setup make [Mega Merge]
Ok so this is kind of a what will it make/does it sound right. The car supposedly dyno'd(?) at 603 at the wheels on E85.
Stock block/bottom end
Cosworth 272's
FIC 1200's(pretty sure)
AMS fuel rail
stock(at least looks it to me) ex. manifold
AMS 3582
AMS FMIC
AMS DP
Tial 38mm
full 3" exhaust(greddy ti I think)
Hallman MBC(not sure of psi of supposed 603)
aftermaket IC piping upper and lower
walbro 255(not sure if its modded at all)
I think thats the gist of it. I'll have to check and make sure
So, do you all think the 603whp is right or achievable with these mods? Will a stock manifold allow that much hp? Single walbro? This is my buddy's new car and it just seems a little high to me.
Thanks
Cosworth 272's
AMS fuel rail
AMS 3582
AMS FMIC
AMS DP
Tial 38mm
Thanks
Cosworth 272's
AMS fuel rail
AMS 3582
AMS FMIC
AMS DP
Tial 38mm
Thanks
Cosworth 272's
AMS fuel rail
AMS 3582
AMS FMIC
AMS DP
Tial 38mm
Thanks
Quick question for those that have seen bazillions of dyno results and estimate numbers.
I have a stock turbo IX with an HKS or Perrin intake (I have both, HKS on it now, Perrin is bnib). The exhaust is jacked. It was welded and mangled by a dealership to get it to pass inspection, and it is about 2.25".
I have a 3" HFC and a Tanabe Medalion Touring in my garage that are going on the car, and I also may put a Buschur-ported exhaust manifold on it that I think I'm getting in trade. However, as the flanges were cut off the downpipe and welded, I need a downpipe.
I've been told the stock downpipe reduces noise and drone, which are hugely important to me.
Are the gains going to be much different from a used stock downpipe vs. an $80 2.75 ebay downpipe on my modest exhaust? And if I put an aftermarket downpipe on it, will it be louder? I've searched and feedback is all over the place on both noise increase and power increase.
ok so I finally got my car back last friday and needless to say I am very pleased. With a fully built 2.1 L on 31 psi with 93 + meth it put down 665.6awhp. My goal was to hit 600 so I am definately not disappointed at all. I really kinda feel that it has more left in it.
2006 Evo IX MR
Stock block 2.0
Stock Head
GM 3 Port
ETS Intake
Buschur HTA3076r Cast Manifold Turbo Kit
Buschur Double Pumper
RC 1600cc injectors
ETS 3.5 IC w/2.5 upper and lower piping
Buschur TBE
Kelford 272 Cams
Dual Tune 91/e85
How much powa? 91? e85? Mustang dyno, Road Race Engineering dyno
Stock block 2.0
Stock Head
GM 3 Port
ETS Intake
RC 1600cc injectors
Buschur TBE
Kelford 272 Cams
Dual Tune 91/e85
No, I was going to order it in the next few weeks. Do you recommend the tubular mani instead? I heard they crack and that's a lot to spend on something that can crack with no guarantees it won't.
All I know is the cast makes less HP and has more backpressure than the Tubular, David Buschur himself will talk you out of his cast kit. I have had two tubular kit's none of them cracked a ETS and Buschur kit James Reese will say the same thing about the BR cast kit. But check this out if you want cast with tubular performance. Most of theBig names have a warranty on the Tubular kits also
https://www.evolutionm.net/forums/ve...turbo-kit.html
2003 evo gsr
walbro 255
hks cams
hks cam gears 272
hks drop in filter
greddy 720 injectors
greddy evo2 catback
jic downpipe
megan 10.5 hotside
evo 9 dv
tuned by fftec for 91
anyone got estimates?
edit: Just got an old mustang dyno chart.
reads 281@ 6000rpm
and 292tq@3750.
is the "conversion" still +12-15% to dynojet?
walbro 255
hks cams
hks cam gears 272
hks drop in filter
greddy evo2 catback
jic downpipe
megan 10.5 hotside
evo 9 dv
reads 281@ 6000rpm
and 292tq@3750.
Man I love this game... Ok, planning for my next build I'm wanting to stay in the mid 600whp range. Where would I be sitting with;
BR 2.3RPM
BR Stage 3 Head
BR 272 Cams
BR Race I/C and piping
BR Fabbed IM
BR 65mm TB
BR T67 Kit
BR CatBack
BR Double Pumper
FIC 2150's
on e85
BR 2.3RPM
BR Stage 3 Head
BR 272 Cams
BR Fabbed IM
BR 65mm TB
BR T67 Kit
BR CatBack
BR Double Pumper
FIC 2150's
on e85
BR 2.3RPM
BR Stage 3 Head
BR 272 Cams
BR Fabbed IM
BR 65mm TB
BR T67 Kit
BR CatBack
BR Double Pumper
FIC 2150's
on e85
BR 2.3RPM
BR Stage 3 Head
BR 272 Cams
BR Fabbed IM
BR 65mm TB
BR T67 Kit
BR CatBack
BR Double Pumper
FIC 2150's
on e85
that setup will max any turbo you put on it pretty much.. mid 600's? theres a selected few good turbos for that power.. fp black, hta86, efr turbo, one of the new garrett gtx series turbos, etc.. lots of options.
the t67 would do it, but its gonna be as responsive as a black on a 2.0L so the 2.3 is going to 100% waste. that turbos over 5+ years old
2003 evo gsr
walbro 255
hks cams
hks cam gears 272
hks drop in filter
greddy evo2 catback
jic downpipe
megan 10.5 hotside
evo 9 dv
reads 281@ 6000rpm
and 292tq@3750.
walbro 255
hks cams
hks cam gears 272
hks drop in filter
greddy evo2 catback
jic downpipe
megan 10.5 hotside
evo 9 dv
reads 281@ 6000rpm
and 292tq@3750.
