How much power will my setup make [Mega Merge]
Old Aug 24, 2018 | 12:41 AM
  #1186
TomekEVO's Avatar
Originally Posted by 2006EvoIXer
Which turbo? If you have IX turbo, you could be in 340whp on 91 and 410whp on E85 give or take 20whp. I'm assuming you have stock injectors and cams.
stock 2003 evo 8 turbo stock cams/injectors
Old Mar 6, 2019 | 11:57 AM
  #1187
Brandoboosts's Avatar
i'd say 600+ with a good tune and e85. only thing that might hold you back a bit is those 1200
Old Mar 15, 2019 | 12:40 AM
  #1188
Sascha's Avatar
Any ideas about my plan?
Evo VIII
Forged Internals
2.2l Stroker
FP Green with 84mm Surge Cover
272 Cams or 262 (not Sure about)
Will run on 98 octane.
Exhaust wise i already have this:
Race Spec Manifold, Invidia Turbo Outlet, 3" DP, 200cell Cat, Milltek Catback
Brething should also not be a problem:
HKS Intake, big intercooler piping, 3" ETS Intercooler
Old Apr 14, 2019 | 07:47 AM
  #1189
wargasm009's Avatar
Just picked up a bone stock low mileage VII and plan to do a mild street build.
90 octane is the highest grade fuel we have here and I don't plan on going meth.
- 3" Intercooler with piping upgrade
- Walbro 255
- 1000cc injectors
- HKS 264 Cams
and relevant supporting mods
I'm still weighing my turbo options and really need some help deciding which direction I should go
How much power am I looking at with:
- Stock 9.8T
- Stock 9.8T with 20g compressor upgrade
- Stock IX turbo
- Stock IX turbo with 20g compressor upgrade
Old May 29, 2020 | 07:51 PM
  #1190
Shamsiel's Avatar
Veteran: Army
I pretty much know what this will make but hey I figured posting up here is a rite of passage at this point. Car will be tuned on pump e85
Evo 8
Head:
-GSC S3 cams
- Ported
- Ferrea everything, stock valve sizes
Block:
Stock spec 2.0
- 85.5mm CP pistons 9-1 CR
- 150mm Turbo Tuff rods
- Eagle 88mm crank
- Half filled and Oringed
Fuel:
- Dual Walbro 450s on Buschur double pumper
- DW2200cc injectors
- 8an feed 6an return
- Aem fuel rail
- Areomotive fpr
Bolt ons:
-Ported Skunk2 Intake manifold
-S90 74mm tb
-FP Super94 W tial .82 vband housing
-JMF GT35 vband manifold w tial v44 wastegate
-2.5 ets uicp w tial q bov
-ets licp
-Sheepey race 3.5" fmic
Misc:
-Haltech elite 1500
-Omni 5 bar map sensor
-JDC Denso COP
Old May 29, 2020 | 07:54 PM
  #1191
Shamsiel's Avatar
Veteran: Army
Evo VIII
Forged Internals
2.2l Stroker
​​​​​​​Your bottleneck is your turbo. Look to the lbs/min and you'll know your max power potential. Looks like it'll be around 500whp on a dynojet imo.
Old Jul 27, 2022 | 10:18 AM
  #1192
Oscar32's Avatar
Cylinder head you are lacking important parts. Cylinder heads that you don't modify can lead to fatal problems. . It is recommended to add a high-strength valve spring kit, you can exchange for a safer engine and better engine horsepower.
DG Motors
Evo X Dyno Results
25
Dec 10, 2009 11:07 AM
mannerism
32
Aug 23, 2009 02:18 AM
mannerism
40
Jun 3, 2009 01:52 PM
sabastian458
Jan 12, 2009 07:29 AM
Sharkbite2000
95
Nov 27, 2008 09:09 PM
