How much power will my setup make [Mega Merge]
i am going to get dynoed this week or early next week my set up is
Evo IX SSL
- 4g64 2.4L ,
-wiseco hd 10:1 pistons
-Manley turbo tuff I beams long rods
-stock 4g64 crank
-Mivec Gsc s2, super tech springs and tt retainers
-Mpfab ts/t3 manifold
-gtx3076 t3, twis scroll 1.06 ar housing
-ID1000
-walbro 450lph
-CC twindisk
- full 3" turbo back exhaust
-hallman mbc
-hks bov
-4" intercooler
-pump gas evoscan flash
will boost till i see knock
may be around 29-31 psi
any guesses on what i can make?
Evo IX SSL
- 4g64 2.4L ,
-stock 4g64 crank
-ID1000
-walbro 450lph
-CC twindisk
-hallman mbc
-hks bov
-4" intercooler
Some questions
My current setup:
Injen Intercooler Pipes
Stock Intercooler
Stock turbo 9
Turbo Back Exhaust - Greddy with a cat
K&N Intake
Goal is 400hp on E85.
1) can I get this reliably/safely with a stock intercooler?
2) I am planning on converting to SD and Tephra Tune - so that is a done deal
3) I take it a ported 02 housing is necessary?
4) I have a test pipe or I'm going to have a muffler replacing the cat (more quiet) and more horsepower. so that is a done deal
5) do I need a fuel pump? Might as well go with the big one Walbro E85 400 if needed
6) do I need injectors? If so I might as well upgrade once for the future 600-700hp for long term future
Goal is *reliable* 400hp on E85, or E70 (safer in case a bad tank of gas) and little to zero knock, but I guess with Tephra mods I can tune for E85 and cut boost if knock or AFR comes up.
thanks,
-Matt
My current setup:
Stock Intercooler
Stock turbo 9
K&N Intake
thanks,
-Matt
yeah why not.
wiseco 8:3:1 compression pistons
molnar rods
acl bearings
arp studs
1mm oversize valves
beehive springs ti retainers
standard TB and intake for the moment
255l intake walbro, 1000hp external pump 2000cc ID injectors
sinco ex manifold
greedy intercooler
gtx3582r on e85
hoping for 600hp on e85
molnar rods
acl bearings
arp studs
1mm oversize valves
sinco ex manifold
greedy intercooler
gtx3582r on e85
I'm curious what my setup is currently making. I am running E85 at 40psi. Here is the list.
APM Built 2.0
MAP Ultimate Duty Billet Steel Connecting Rods
Wiseco HD 1400 Pistons (9.0:1 CR / .20 over)
ACL Race Bearings (Rod & Main)
ARP Main Studs
Gates Timing Belt
Kiggly HLA
APM CNC IX Head (O-ringed / Non-Mivec)
GSC S3 Camshafts
MAP Ultimate Duty H11 Headstuds
Supertech Intake/Exhaust Valves (+1mm on both)
GSC Beehive Valvesprings w/ Titanium Retainers
SpoolinUp COP
Torque Solutions Engine Mounts (All 4)
Mishimoto Aluminum Radiator
STM Radiator Brackets (Black Anodized)
STM Remote Coolant Resevoir (Polished)
Nisei Small Battery Tray
Intake:
"ETS 4.5"" FMIC w/ 3"" Outlets (Garrett Core)"
Magnus V5 Intake Manifold (Wrinkle Black by Tirado Coatings)
Boomba 75mm Throttle Body
"APM UICP/LICP 2.5
Tial Q 50mm BOV
"STM 4"" Intake"
Amsoil & K&N Filters
Phenolic Gaskets (Throttle Body & Intake Manifold)
Ram Air Headlight / Velocity Stack / Intake Tube (Drag Race Only)
Exhaust:
Shearer T3 Manifold
"Shearer O2 Housing (3"" V-band for Garrett GT turbine)"
FP HTA3794 Turbo
Tial 44mm Wastegate (21psi base spring pressure)
"JUN BL 3"" V-Band Catback"
Buschur Racing SD Muffler (V-Band / In place of testpipe)
Buschur Racing Downpipe (V-Band)
Fuel:
FIC 2150cc Bluemax High Impedence Injectors
Buschur Double Pumper (Dual Modified Walbro 255's)
Perrin Fuel Rail
Fuel Lab Mini-FPR
AMS Fuel Feed Line
SpoolinUp Quick Connect Injector Clips
APM Built 2.0
ARP Main Studs
Gates Timing Belt
Kiggly HLA
GSC S3 Camshafts
SpoolinUp COP
Intake:
"APM UICP/LICP 2.5
Tial Q 50mm BOV
"STM 4"" Intake"
Exhaust:
Shearer T3 Manifold
FP HTA3794 Turbo
Fuel:
Perrin Fuel Rail
Fuel Lab Mini-FPR
AMS Fuel Feed Line
I wanna play...
Stock ECU/MAF
BR 2.3rpm
BR stage 3 head
HLA
Baffled oil pan
BF 272
HKS RS intake
Forge DV
BR Deluxe FMIC
Upper/lower IC pipes
3" down pipe to exhaust cutout
Stock ported exhaust/intake/65mm tb/02
Double pumper
FIC 1050cc injectors
64mm JB FP Red
E85 @ 34 psi
Quartermaster 8 leg
Bushwhacker trans
Bushwhacker tcase
Stock ECU/MAF
BR 2.3rpm
BR stage 3 head
HLA
Baffled oil pan
BF 272
HKS RS intake
Forge DV
BR Deluxe FMIC
Double pumper
64mm JB FP Red
E85 @ 34 psi
Quartermaster 8 leg
Bushwhacker trans
Bushwhacker tcase
Sounds about right. Although with the big jump in numbers everyone sees from going from HKS 272 to GSC S3, plus a 2.3 motor and port work all around, I would hope to see closer to 600. I'm thinking of going to 1200cc injectors
is urs a mivec? if so i would recomend gsc s2 (my opinion). that cam is more than enough for the red. and spend the extra dough and get the mother fludpukin ID or FIC 2000cc. i F'ed up and got the 1000cc but the tuner told me they can be made to flow 1400-1500cc with the right fuel pressure. on e85 u will do more then 550 dyno jet (my guess). and e85 ur injectors will need to be alot bigger.
Non mivec.
I made 460/430tq on dyno jet with
Stock ECU/MAF
Stock throttle body/IM
2.0
HKS 272
FIC 1050cc
Forge DV
BR deluxe FMIC
BR IC pipes
3" down pipe to cut out
HKS RS intake
Double pumper
64mm FP red
E85 @ 34psi
Tuner said there was still room on the injectors
Stock ECU/MAF
2.0
HKS 272
FIC 1050cc
Forge DV
BR deluxe FMIC
BR IC pipes
HKS RS intake
Double pumper
64mm FP red
E85 @ 34psi
How Much WHP Can it Have
I have A 2006 Evo Ix Mr
I done some moods and would like to know how much whp can it have on a dyno??
Mods
-short ram intake
-Ported head
-hasting piston rings
-rebuild turbo
-hks Bov
-SR-S delete pipe
-3 port greemspeed boost controler
-stage 4 clutch with 8.2lbs flywheel
-ARP head studs
Mods
-short ram intake
-Ported head
-rebuild turbo
-hks Bov
-SR-S delete pipe
-ARP head studs
