How much power will my setup make [Mega Merge]
Old Nov 28, 2013 | 06:04 PM
  #1111
Werdna06's Avatar
i might could squeeze injectors in but the intercooler is prob a nogo. what kind of numbers do you think i would get with what i have now?
Old Dec 3, 2013 | 03:00 PM
  #1112
Shinzon's Avatar
Originally Posted by anwkid
Hey guys im just about ready to drop in my new build. Im looking for some awesome torque numbers low in the band but im afraid i may have sized the turbo too big.. Anyways if you guys have any idea on what I can expect power wise and what my possible bottle necks will be Id be interested to hear it! Thanks in advance!
03 GSR
self built 2.4LR
Manley turbo tuff series billet 100mm crank
Manley turbo tuff series I beams, HD pin, ARP625 bolts, 156mm length
Wiseco forged pistons, hard annadized, ~10.5:1 87mm bore
ACL race series bearings
Girdle doweled and ARP studs
Cometic MLS headgasket
Stock head and cams for now
ARP L19's
AEM adj. cam gears
Full 3"-3.5" Exhast (custom)
ID 1450cc injectors
E85 + water/meth if needed
Grimspeed 3-port + Grimspeed MBC (hybrid boost)
HTA 3582
XS power tubular manifold
44mm external wastegate
AMS IC
stock route piping
4" SD intake
600-700 with bushar double pumper, a good clutch, bigger intake manifold, s2/s3 cams. but if all your building is the bottom end than 500+. that 2.4 likes to suck air.
Old Dec 4, 2013 | 09:00 AM
  #1113
anwkid's Avatar
Thanks for the reply, how much of a restriction do you think the stock head will be. I have a double pumper, afpr, and exedy twin disk. I can get cams and an intake, but the head is a big chunk o change!
Old Dec 5, 2013 | 02:41 PM
  #1114
Shinzon's Avatar
porting is the best u can do, maybe bigger cams. ur 35 might give ur clutch a workout. intake manifold will help alot. ignition too. im having issues with my gt3076 with 1.06 housing. the turbo likes topend but advancing timing is not giving me power. im going to log intake temp to see whats going on with the charge system. im too scared to play with the mivec system.
Old Dec 6, 2013 | 12:27 PM
  #1115
bratz_729's Avatar
Here we go. Setup is:
Evo 8 turbo 10.5 hotside
Aftermarket licp
Hks intake
Megan manifold
Megan o2
3" exhaust
Built 2.0 bottom
Hks 272 cams
Tuned to 21 psi on 91 octane
My guess is around 300 ish?
Old Dec 6, 2013 | 03:05 PM
  #1116
Shinzon's Avatar
27-29 psi gets u 340-350 on pump
Old Dec 6, 2013 | 03:27 PM
  #1117
bratz_729's Avatar
I may have to retune for some more boost then. After I get a pump an injectors
Old Dec 7, 2013 | 12:22 PM
  #1118
NUR's Avatar
NUR
Evo8 GSR - 1)HKS catback exhaust 3) HKS Racing suction Intake 3) Walbro 255lph fuel pump 4) AMS fuel Rail 5) 1st Gen FP GREEN JB turbo 5) RC 1000cc injectors .... the injectors are on their way, other than that everything is installed currently at 286whp and 290tq at 21psi (Dynapack 5000) (Stock internals and clutch ) How much should i expect after the injectors are installed? 91octane btw
Old Dec 8, 2013 | 05:40 AM
  #1119
Shinzon's Avatar
with cams 400-430whp , without cams 350-380
Old Dec 8, 2013 | 08:28 AM
  #1120
NUR's Avatar
NUR
Thanks, was expecting something around 350 well have to upgrade the clutch
Old Dec 23, 2013 | 05:58 PM
  #1121
LaFuriaRoja01's Avatar
Figured I'd give this a shot for the hell of it.. Right now I still have a single cam 4G64 on 12psi however I'm nearly ready to begin my build in the spring.
4G64 stock bottom end
9:1 CR
Ported G4JS dual cam head
BC 272 cams
HKS adj. gears
T3/T4 T04e
2.5" straight pipe TBE
650cc injectors
Walbro 255
Blox FPR
Direct port 50/50 meth injection
32" front mount intercooler w/water sprayer
S90 70mm TB
2.5" intake piping
Aluminum intake manifold
GM MAF-T
Stainless steel tubular turbo manifold
AC+PS delete
SpoolinUp non-CDI COP
Tune on ECUflash
Stock 3G Eclipse fuel rail, fuel lines, etc.
Don't know what kind of boost I'll be running but I'd like to see over 20psi. It's a 4AT Eclipse, FWD, trans is stock internally with low miles on it and a massive bar and plate cooler.
Old Dec 26, 2013 | 09:41 AM
  #1122
ScoobySport91's Avatar
Veteran: Marine Corp
with my current mods in my sig, i made 320/290
furture mods- 1250cc, fpblack, test pipe, on 93 octane
how much will i make with those future mods?
Old Dec 27, 2013 | 08:45 AM
  #1123
wwcagedevo8's Avatar
Fp black is a serious turbo. Should bring out some 400-500 on pump. The only issue is you may need to mod the 255 by pushing the relief valve in to make it keep up or install a inline fuel pump under the hood with a Hobbs switch.
That turbo is more for race gas/e85 to make it worth while. 600-650 is obtainable on that gas with of course another fuel pump.
Old Dec 29, 2013 | 12:34 AM
  #1124
Alexevo09's Avatar
Hello. i have evo 4, forged JE pistons, standart bore, eagle rods, acl racing bearings, walbro, hks intake, evo 8 ecu, other parts are stock. how much hp can i get on 98 fuel?
Old Dec 30, 2013 | 12:06 PM
  #1125
ptm5070's Avatar
Evo viii.... got and idea of how much power and torque?
FP Red turbo
GSC S2 cams
Beehive springs and Ti Retainers
AMS intercooler
Injen Intake and IC piping
Boost turned up around 25psi
Turbo back catless exhaust
K&N Air filter
Buschur Tuned- But will get new and better tune
Walbro 255 fuel pump
1000cc injectors
Thanks!
