just rebuilt and cant get it to start. help!
Old Nov 29, 2009 | 03:35 PM
hastyman14's Avatar
i just rebuilt my motor and i cant get it to fire. i put a new crank head studs bearing fully redone head rings nothing to major. the crank sensor went out so i put a new one in so i have spark now but it looks like its barley throwing any spark and almost like its got a miss. the idle/air module broke changed that out. ive tried feather the throttle to try and get more air in there. pulled the fuel line at the fuel rail and it shoots a stream out. the motor turns over amazing. if you any thoughts please let me know.
Old Nov 30, 2009 | 12:50 AM
BCspeed34's Avatar
Check your electrical connections, you might have a bad ground connection.
Old Nov 30, 2009 | 01:16 AM
neodestroyer's Avatar
You should also check your voltage levels. It needs to be at least 12v for the car to start. You can even pull the coil packs(leave them hooked up to the wire harness) and try turning over the car to check if they are sparking. Also do a compression check and even check your timing.
Just try some of those things and let me know.
Old Nov 30, 2009 | 04:31 AM
20gmr's Avatar
did you changes cams at all? If you put the trigger wheel on the end of the cam 180 degrees out it will act weird. I would also look at the cam timing.
Old Nov 30, 2009 | 04:34 PM
hastyman14's Avatar
ya ill have to check all the grounds again and as far as voltage i had the battery charged and jumping it with another car. and when i pulled the cams that trigger wheel might hav epun around. is there anyway that you can check to see if has been spun around?
Old Dec 6, 2009 | 12:02 PM
20gmr's Avatar
You would have had to unbolt it to do so. It can only go on 2 ways, one way is correct and the other is 180 degrees off
Evonick26
16
May 17, 2016 05:51 AM
moyassine
Feb 21, 2016 10:54 AM
tvor
Aug 20, 2015 02:10 PM
Deathjoker
Lancer Engine Tech
Aug 8, 2011 08:05 AM
evoxsi
Jan 11, 2008 12:08 AM
