Norris Designs - Supercharged & Turbocharged kit!
I have been following the evo 5 thread. You cant really tell anything from video. You cant see the tach, the speedo doesnt work either. And there is no dyno posted. He did say he was making 480tq at 4000rpm like that was impressive. I have seen a local FP black make 570wtq at 4100 rpm on a stock 2.0. The whole purpose of a twin setup is to gain a broader power band than what can be achieved with a single setup. The only setup that worked from very low rpm and made stupid flat torque was the norris setup. twin turbos arent capable of such a feat. unless is setup as sequential. but most are onto the compound turbos. they give big turbos better spool but they fall short in the low rpm below 4000. they also choke up top more because most the exhaust still has to go through smaller turbo which creates high back pressures
Let me tell you guys...
I have driven the 1.4 Tsi engine on a VW Golf in Europe and i have to say, amazing. We are talking for a 1.4 liter engine with the low down torque of a 2.5!!! i drove the "small" 140hp version for about 1000 miles but they also have a more powerful version with 170hp and 177 ft/lbs from 1,750 to 4,500rpm.
On a larger scale this will be very impressive. Its 100% doable since VW uses it in a massively produced engine/car.
I dont think the evo 5 is bypassing the supercharger. you can here it the whole time. so the torque curve will fall at higher rpms due to inefficiency of surpercharger in the way.
If some one could just share what supercharger setup was used I would consider building one of these. It may actually be from the 1.4 engine. There is a toyota roots charger being sold regularly on e-bay right now. they come with clutch and bypass valve. but the engine was a 2.4. the charger looks to be on the large side for the project. it came on a toyota previa. I cant find a dyno curve of the previa anywhere. but it may have impressive torque at 2000 rpm. then shuts off charger at cruise speeds.
239 bhp = 178kw
178kw = 607,523 BTU
I dont have the formula to convert that to specific heating (in this case melting) terms, but I seem to recall someone on NASIOC posted this in regard to the Subaru tranny and it was something like 420*F in short order, but the thermal loss wouldnt stop right away. It would get hot enough to melt the transmission as I recall.
Your setup has not bested one good hta86 setup on a 5 speed.
you need to learn how to read a dyno graph..
Kevin, all your babel completely useless to me. I am interested in the twin charge setups that make a nice road car. When you have that built I will listen to your experience on the subject. I know your setup works very well for its intended purpose. Its just not at all what i am after. The only dyno graphs posted of compound turbo setups that are worth looking at are from CPR. and they clearly are also not what I am after. no power below 4000rpm doesnt work for me. I am looking for the broad (starting at low rpms) like the VW 1.4 produces, or the Porsche twin turbos, or the best I have seen hands down the Norris project car.
i dont have much to input on this but i saw something about a previa s/c and i have to say i have one and it is fun as hell to drive in the rain. Def enough torque to get sideways but it only make 3 or 4 psi if i remember correctly, but i dont know where its peak efficieny is
Well, that's a little better. I'm glad we had this conversation.
I understand that compound turbos are not for everyone. When you build whatever it is that gives you what you want, be sure to post the data, I'm always interested in hearing more about these unusual setups.
I have seen the previa chargers. They are correct design for the task. They have clutch to disengage the unit after boost is achieved. They have the baypass, but the bypass valve would be far too small for our purpose. The 2.4 previa engine achieves 200tq at 3500rpm with 6psi. Not sure if it would be correct size for project. It may be just right with smaller drive pulley. The norris car made 300tq just over 2500rpm on a 2.4.
The dyno graph posted of the norris car was also not the finished tune. it made 1100 hp with .2 bar more boost!
Kevin, i am not sure the compound setup incapable of giving me what I want. Of all the setups i can find they all using too large primary turbo (first to see exhaust) . It may give the results I am after with something like a 14b/35r setup. I built a 2.4 years ago that was built for a 35r. It was run with a 14b on it for a month. I may be one of the few on the planet that has felt a 4g63 with that much low end. But i tell you what. That car was an absolute blast to 5000rpm. boost started at 1800. had 21psi by 2100rpm.
The superchargers setups are better design in a sense the charger can step out of flow path after boosting. But far more complex. A twin turbo setup sounds much more simple to me and ultimately more reliable. as we know turbos at 20psi live forever.
A 14b and a 35R are a reasonable match.
The 14b/35R combo would be nice to see some numbers on. Most people wouldn't bother since they can live with a 35R sized turbo on its own, you'd probably be the only one willing to try it. I need back pressure numbers on at least one other setup that's a good bit different in size than mine to start to determine what the trends are as you change turbo sizes. I may swap to a .63 housing on my 50 trim to spool up a little quicker for competition, but the cost to benefit ratio is too high. It would be one more data point though, even if it's not much of a difference. I'm currently a touch above 1:1 (~47 psi drive pressure at 45 psi manifold pressure, through a 4" FMIC) with crossover happening at or above 8000 rpm, which isn't bad for a turbo that "spools" at 4000 rpm. I would expect the 14b setup to go vertical at 3000 rpm in my setup, but on a 5 speed where you can load it better it should do even better than that.
Just for fun, a compound Pocharger setup recently went 4.008 in the eighth mile too BTW, for another type of setup that's doing well. Gets on the converter instantly...
If you need some, there are plenty in New Zealand
http://www.trademe.co.nz/Browse/Sear...ch_suggested=0
