EPM o2 dump installed. what next?
Old Dec 1, 2009 | 08:39 PM
daechul2da's Avatar
WOW~~!! EPM o2 dump is a pain to install. i went with not taking the radiator
off. almost poked a hole through it. i think taking the heat shield off the stock o2 housing was the hardest. the sound when full throttle is great . Now thinking of getting a tune soon.. what do u guys think should be next?
current setup:
Megan TBE
epm o2 dump
BC 272
buschur intake
forge MBC
walbro fuel pump
niesi LICP
what should i do next?
was thinking about getting better cams
(kelfords272. gsc s2). is valve springs a MUST?
my final goal is to get a fpred and get around 450whp. i'm trying to do every supporting mod before the turbo upgrade. any suggestions?
Old Dec 1, 2009 | 08:46 PM
jeri534's Avatar
FMIC w/ Piping
You should do springs if you do S2s and Kelford 272s, you dont need springs with the S1s though.
bluebanana23's Avatar
I'd do intercooler before upgrading to larger cams. Springs are not required on the Kelfords if you stay with the factory redline. You might as well install them along with the cams though...
Old Dec 1, 2009 | 09:11 PM
daechul2da's Avatar
thx guys. intercooler and pipes it is then..
Old Dec 1, 2009 | 09:52 PM
Kingofvacuity's Avatar
Yeah intercooler and pipes and you'll be happy for a bit
dank420
Mar 19, 2011 04:26 PM
BEISSEN
Oct 22, 2010 09:02 PM
JBud72
14
Jun 19, 2009 10:56 AM
xmaciek82x
18
Mar 11, 2009 08:58 PM
Q@EvoPowerMods
Feb 17, 2009 10:14 AM
