This is what happens when you add a fuel pump without tuning
Old Dec 5, 2009 | 01:55 PM
MR Turco's Avatar
I have swapped to a walbro on numerous cars without affecting AFRs. If the pump is worn or old or running at 100% duty cycle, changing to a new pump will affect the tune and fueling.
Old Dec 5, 2009 | 01:59 PM
leecavturbo's Avatar
Originally Posted by Unregisterd
I don't think one of us is looking at that graph correctly. What I'm seeing is a loss in power from the Walbro w/o a tune due to richer AFR.
I've heard both theories, but this seems to confirm the need for a retune after adding the Walbro. My tuner said I'd need to retune also, so I've been following his advice and waiting to install my pump until I get the new injectors in also.
your right well spotted
Old Dec 8, 2009 | 09:39 AM
EmeryatSTM's Avatar
Ive probably done a 100 of them now and every single one has needed the AFR retuned.
-Em
Old Dec 8, 2009 | 09:47 AM
SyZyGy1394's Avatar
-Em
Only makes sense if you are close to maxing out the stock fuel pump, right?
When I was on the stock fuel pump, and switched to a walbro I noticed it definitely went a little richer.
Old Dec 9, 2009 | 06:09 AM
mazpr's Avatar
I was wondering, Is it that safe to be running at 13.0 - 13.3 AFR?
Old Dec 9, 2009 | 01:27 PM
OneEyedJack's Avatar
Originally Posted by nickcarlson1
i CAN be incorrect about this, but i believe the stock pressure regulator can only help an aftermarket pump by not letting the pressure get too low so it doesnt run lean. it cant compensate for the pump trying to run a higher pressure, which seems to be the case with these numbers.
Mechanical pressure regulators reduce pressure from their inlet to their outlet. They are not capable of producing a higher outlet pressure than their inlet. By design, they compensate for higher pressures, but if the inlet pressure drops below the outlet set pressure, there is nothing a regulator can do about it.
The issue you see with an aftermarket pump and AFR issues is intrinsic to mechanical non-adjustable regulators.
One of the springs in the regulator is pre-loaded to deliver a specific pressure at its outlet. This outlet pressure varies within a range based on the inlet pressure and down stream restrictions during dynamic conditions. With an adjustable pressure regulator, you are able to dial in the pre-load on this spring.
Extremely high performance regulators are capable of maintaining very close to their set outlet pressure even as inlet pressures climb. It's no wonder, however, that most automotive FPRs are not "extremely high performance."
So, as the inlet pressure increases, so too will the outlet pressure to some degree, since the pre-load on the regulator spring has not varied in relation to the inlet pressure.
evogirl916
Mar 19, 2011 08:46 PM
David Buschur
Jan 8, 2011 01:02 PM
4g63girl
Nov 19, 2010 08:25 AM
EmeryatSTM
May 13, 2010 10:53 PM
David Buschur
74
Jan 17, 2007 07:09 AM
