turbo questions
Old Dec 5, 2009 | 10:06 AM
BryanEG6's Avatar
turbo questions **updates pg.4!**
**UPDATED 1/14/12 pg.5!!**
well, you guys are gonna love this...
i picked up a TDO5H 16g off a EVO 8 and i have some questions. the turbo itself only has 3000 miles on it, and is just the turbo w/ stock wastegate. no vac/water/oil lines attached to it. questions are...
since the car will not be a DD are the water lines totally necessary?
what psi does the stock w/g actuate at?
is the O2 bunge fairly universal? (got the invidia O2 "outlet" piece)
where can i buy just a flange to attach to the O2 outlet for my downpipe?
any answers/advice is much appreciated.
btw.. this will be going on to my B18 EG civic hatch
Old Dec 5, 2009 | 10:30 AM
mazpr's Avatar
Fail
Old Dec 5, 2009 | 10:47 AM
BryanEG6's Avatar
Originally Posted by mazpr
Fail
dont be mad the header I have going to "your" turbo is sexier than what you got
I'm sure 90% of you will despise me for this setup. thats ok, haters are motivation. I LOVE reelin in and passing AWD cars after they take off like a bat-outta-hell
Old Dec 5, 2009 | 12:53 PM
SCREAM8's Avatar
yes, this turbo was designed to run on a wet set up.
stock evo 8 turbos boost to 19 +/- and settle to around 12-13. the WG itself i believe cracks around 12 psi. however, i could be wrong.
with stock set up turbos, any o2 housing set to run with the stock design will fit. the invidia being one of them.
i dont know of any places that just sell the flange, but you could always look for used downpipe and cut/weld it.
Old Dec 5, 2009 | 12:59 PM
minievo82's Avatar
According to my Greddy Pro-Fec B my w/g starts to crack at 11.8. Just like Nickcarlson1 stated the turbo is designed to run with the water lines. I would really suggest running it with out one.
Old Dec 5, 2009 | 03:26 PM
BryanEG6's Avatar
thanks for the helpful info
Old Dec 5, 2009 | 03:41 PM
justboosted02's Avatar
youre gonna need more than a stock evo 8 turbo to do that...
Old Dec 5, 2009 | 03:43 PM
blkmkIII's Avatar
- i would run water lines as it will make the turbo run alot cooler therefore making it last longer
- stock wg is .5bar(imsure you will run some sort of boost controller.)
-as for the o2 side. youll want to fab up a 1 piece downpipe. (google 16g flange) do not use a 02 housing. your also not the 1st person to put a 16g on a b series. hope this helps.
Old Dec 5, 2009 | 04:20 PM
MR Turco's Avatar
How about everyone be a little more respectful?
I think this is a really cool concept.
Old Dec 5, 2009 | 04:34 PM
BryanEG6's Avatar
my hatch weighs barely over 2000lbs with me in it. it dont take much to make it go fast. I'm shooting for 250-260 FWHP out of this setup, which will be on a conservative tune. with that power it will run mid-11's... and, i bet i get that kind of power under 14 psi.
a stock Evo with a good driver pulls low 13's...
Old Dec 5, 2009 | 04:39 PM
LOVEBOOOST's Avatar
a boost controller, intake and a tune it will go 11s!! Go search and u find out!! With a good driver
Old Dec 5, 2009 | 04:43 PM
BryanEG6's Avatar
Old Dec 5, 2009 | 04:46 PM
JohnDoe1984's Avatar
Who races a completely stock evo? They're capable of mid 11's with a MBC, fuel pump, intake, exhaust, tune, and a good driver. Somewhere in the 12's probably just by ditching the pig rich stock tune.
Most evo's you find that actually want to race are going to be 350whp+.
Old Dec 5, 2009 | 04:47 PM
esmjoe's Avatar
I'm actually put this turbo into a customer's 2007 Honda Civic SI..His choice..I will be making the flange myself..I will be reusing the water circulation because of efficiency issuse..daily driver..Good luck on yours..
Old Dec 5, 2009 | 04:48 PM
BryanEG6's Avatar
thats why i said *stock*
theres no doubting the potential of Evo's. thats for sure. i plan on runnin a EBC on it and definitely will be spending a good bit of time on the dyno.
