Cam help
Old Dec 8, 2009 | 07:38 AM
Stevo IX's Avatar
Cam help
Ok so im at the point where i need to buy a set of cams for my evo ix. As of now i have a BR stage3 2.0 bottom with JE/Crower internals, My head was just redone with full ferrea beehive valvetrain and valves etc.. Stock intake manifold and 1000cc injectors. I am planning on doing a 6262 turbo kit. As of now im only going to reflash the ecu but i eventually plan to go aem. For now i will run 93 pump gas but I am considering eventually running e85. I am ready to order cams but i want to make sure i get the right ones. I hear from a lot of people that kelford 272's are great cams but after researching i found that they are preffered for the 8's. Can anyone shed some light on me as to which cams would be ideal for my setup. Thanks
Old Dec 8, 2009 | 08:07 PM
Stevo IX's Avatar
no one??
Old Dec 8, 2009 | 08:31 PM
PaperClip's Avatar
check out stikiller.com
they have some nice cams
Old Dec 9, 2009 | 11:41 PM
Stevo IX's Avatar
Yeah they have some nice ones but which ones would you guys recommend
Old Dec 10, 2009 | 12:09 AM
BLKCarbonEVO's Avatar
GSC S2s. imo They are the best cams until you decide to jump up to the big boys like the S3s or FP5R. I love the 5Rs and you can run those because you should have enough valve clearance with your motor build
I hope you don't mind spooling at 9k with your 6262! lol
The 6262 prob won't spool till 5200 or later...
Old Dec 10, 2009 | 06:40 AM
awd2gen's Avatar
Thumbs up
Go with gsc S2's If you dont want to go with the kelfords. and good choice on the 6262 its a sick street turbo!
Old Dec 10, 2009 | 06:56 AM
How do you figure spooling later than 5k a good street turbo?
Old Dec 10, 2009 | 07:09 AM
Stevo IX's Avatar
Yeah i have also heard good things about the s2's. Between the s2's and the kelfords, which ones would you guys choose. And are you saying that i shouldnt get the 6262??? if so, which turbo should i get then?
